Author Topic: Removing transmission lines  (Read 3822 times)
« on: July 01, 2011, 03:33:13 pm »
Im going to be replacing the transmission lines (old ones were cut by PO and bypass the radiator to just a external cooler). My question is if I drain some of the fluid out of the pan, will that decrease the spill when I remove the lines from the transmission, or do I just wait for it all to drain out? Just trying to keep a mess to a minimum.
Offline Grim 82
Re: Removing transmission lines
« Reply #1 on: July 01, 2011, 04:40:40 pm »
I would leave the pan and just have some rags handy and work quickly to mitigate the mess. You will have fluid running back from the lines as well that you could temporarily plug or cap.
« Reply #2 on: July 01, 2011, 05:18:50 pm »
Sorry, I dont follow the second part.
Offline Grim 82
« Reply #3 on: July 01, 2011, 05:54:18 pm »
When you remove the lines from the trans alot of the fluid loss will be the fluid that's in the lines draining from the tubes from the trans cooler side, as opposed to heaving from the trans itself, so unless you are servicing the trans I would leave your pan gasket intact. It will be messy either way, but then you won't have to replace as much fluid or worry about the gasket leaking later on.
« Reply #4 on: July 01, 2011, 06:24:55 pm »
ah ok, ya i was hoping the only fluid I'd have to deal with was what's in the lines, and that's ok. Good to know I shouldn't have fluid coming out of the transmission at the connection.
As for the pan, I have a aftermarket pan with a drain plug. Ive replaced that gasket for the last time! ha.
« Reply #5 on: July 01, 2011, 08:59:02 pm »
« Reply #6 on: July 01, 2011, 09:31:01 pm »
neat tool
