Author Topic: How do you remove the key knock-out plugs?  (Read 5474 times)
Offline got2haul
« on: August 13, 2011, 08:04:32 pm »
I installed a new original key cylinder with keys.  The keys have the knock-out
plugs and I'd like to remove them.  How is this done without damaging the key?
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Offline 80stepsideguy
Re: How do you remove the key knock-out plugs?
« Reply #1 on: August 13, 2011, 08:21:36 pm »
Block of wood under the key and use a hammer and a flat screwdriver may work..
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #2 on: August 13, 2011, 10:19:28 pm »
Place the knock out over the vise opening and punch it out with a hammer, and punch.
« Reply #3 on: August 13, 2011, 10:51:34 pm »
Flat screw driver and give it whack. If you have a vice, open the jaws slightly and pop it through
Offline got2haul
« Reply #4 on: August 14, 2011, 05:00:51 pm »
Worked like a champ!  Thanks!
