4 Wheel Drives
steering shaft loose by firewall
Topic: steering shaft loose by firewall (Read 14765 times)
rhagoki
September 22, 2011, 09:56:59 am »
I have an 85 k10 with a problem i've been trying to figure out for some time. Replaced gearbox a while back and hasn't been right since, i could have messed something up and not realized it? Bought new shaft thinking that will fix the problem, but didn't. Have tried several rag joints with no luck. The problem is this, where the steering shaft connects to the column under hood up near firewall is really loose. I pulled the dash apart yesterday and pulled the column almost all the way out to tighten any bolts that might have come loose etc. Still no luck. Pics to follow.
rhagoki
Re: steering shaft loose by firewall
September 22, 2011, 10:31:13 am »
Second image is with me pulling up on the shaft to show the amount of movement it has.
September 22, 2011, 11:37:25 am »
I think I remember seeing a post years ago about this. On my phone or I would search for you. But I think its a bearing someone who knows will chime in soon
September 22, 2011, 11:55:57 am »
Your bearing is toast. Someone just posted about fixing it recently.
rhagoki
September 22, 2011, 04:27:39 pm »
lower retainer bearing? that was all i could find, but thought that was on the inside of the column.
September 22, 2011, 06:27:38 pm »
Get a used column.
rhagoki
September 22, 2011, 06:59:34 pm »
any way to fix this one or is it really just easier for new/different one?
slammed79
Thou shalt not drive stock
September 22, 2011, 11:51:25 pm »
It be less effort to get another column. I see them on Craigslist here frequently for $40-$50
Praise the lowered
bake74
September 23, 2011, 06:47:37 am »
By getting another column you can tear it apart, check it out it you want and not have to worry about tearing yours apart and then needing to find parts that might take awhile.
74 k10, 77k10 Tom
rhagoki
September 23, 2011, 09:17:59 am »
Thanks for the replies, this newbie has already learned quite a bit from poking around on this site. Seems a bit obvious, but with the column being in the shape its in and steering shaft loose i have to assume that the way it drives currently (wanders and shimmies from time to time) is directly related to the column?
September 24, 2011, 09:38:16 am »
Check the front end too, the steering, suspension (ball joints, wheel bearings), tire balance and the frame. Do a dry park check and have an assistant rock the steering wheel back and forth while you observe for any unwanted movement.
rhagoki
September 30, 2011, 04:04:01 am »
Maybe the search has been cleared not finding page im sure I've found before and off topic for this thread. How do you check wheel bearing? Driving with bad one what are some symptoms?
rhagoki
September 30, 2011, 04:06:54 am »
Seems I don't know how to use the search, didn't realize I was searching under just one category ...
bake74
September 30, 2011, 09:28:30 am »
You have to search under the correct topic heading.
74 k10, 77k10 Tom
1979C20
Kyle Taulton.
September 30, 2011, 09:54:41 am »
Or if you search from the home page it searches all topics.
4 Wheel Drives
