Author Topic: How to clean engine for paint  (Read 23451 times)
Offline 9511234
« on: October 01, 2011, 10:08:41 am »
I have the engine out on a stand, intake and pan dropped.  The heads are still on.
What's the best way to clean it up for spray painting some color on the block and heads?
I don't want anything too corrosive that might damage seals, obviously don't want to use water or a liquid that could get in the bottom end of the engine.  I had the pan vat cleaned at the engine shop.
If I took it there is there a process there they could use to clean it without taking the heads off or with the block and rotating assembly in place?
Primarily trying to get grease/sludge off the outside.  There's a little bit of rust, but nothing the paint shouldn't be able to handle.
Thanks for the help.
Re: How to clean engine for paint
« Reply #1 on: October 01, 2011, 10:49:38 am »
     If it is on a rotating engine stand, I would use a degreaser sparingly, one side at a time with a brush and small wire brushes, rotate the engine so you can clean the down side and keep turning, or put your pan back on, and cover (plastic)the other area's and then clean with a solution so as to get the grease off so your paint will stick.  Are you painting or coating it with something like por-15.
Offline mach1mustang351
« Reply #2 on: October 01, 2011, 10:26:16 pm »
Degreaser works well.  I also use some brake clean or mineral spirits because they tend to remove the degreaser helping the paint stick.  Blowing everything off with compressed air helps well too.  Keep the engine inside and warm and make sure the paint can is warm.  It tends to flow better out of the can, in my experience.
Offline roadrage41
« Reply #3 on: October 02, 2011, 01:15:45 am »
make sure the engine as a whole is sealed up, mini wire wheels and compressed air, little bit of brake clean and a scotch brite here and there.
« Reply #4 on: October 02, 2011, 10:36:34 am »
I use all of the above methods, and also Aircraft Paint Stripper. You will need to be careful not to get it on rubber, and your hands. Once the heavy grime is gone with degreasers and a presure washer. the stripper will take off all the old paint. I presure wash the striper off. Then I wire brush, use a mini grinder with scoth brite wheels, and 36 grit wheels. Also use a 3" DA sander to prep it, and a blow gun. For the rusty areas I use Chassis Saver, and the clean metal areas I use a spray bomb self etching primer
( Transtar brand is a good one ). Then paint with a quality top coat.
Few pics of the last one I did.
In the truck.
« Last Edit: October 02, 2011, 08:35:10 pm by Blazin »
« Reply #5 on: October 02, 2011, 03:49:20 pm »
     Hey blazin, is that cat yellow paint.   ;D
« Reply #6 on: October 02, 2011, 04:09:43 pm »
Why yes, it is. Thanks for noticing!! Meoow!!   ;D
Offline Bitzer!
  • Smiles per gallon
« Reply #7 on: October 23, 2011, 04:53:33 pm »
Hi guys, I don't have access to "cack" paint  ;D
Once it's cleaned and etched, would normal 2k paint survive the heat?
I've heard several stories blah blah only use enamals etc?
cheers
1979 GMC CrewCab  C20 1t
Offline Bitzer!
  • Smiles per gallon
« Reply #9 on: October 23, 2011, 05:25:03 pm »
 ;) cheers Vile. Next to decide the colour!
« Reply #10 on: October 23, 2011, 05:45:38 pm »
What color is the truck?
Offline Bitzer!
  • Smiles per gallon
« Reply #11 on: October 23, 2011, 06:14:19 pm »
You mean you haven't been following  ::)
Orange with black roof & black strip down sides.
Thinking orange inner fenders and a black & silver engine?
« Reply #12 on: October 23, 2011, 06:38:21 pm »
Wasn't sure that's what you are working on here but yeah black looks nice
Offline Bitzer!
  • Smiles per gallon
« Reply #13 on: October 24, 2011, 09:38:42 am »
It was either black/silver or silver/black. Can't think of many other colours that would compliment the orange!
« Reply #14 on: October 24, 2011, 11:01:42 pm »
Why not black and orange?
