Author Topic: 700R4 rebuild... what to ask for???  (Read 4160 times)
« on: December 21, 2011, 05:45:12 pm »
OK here's the deal.  Since I have a 700R4 that needs gone through I thought I would put an ad on Craigslist on the barter section and see what would come of it.  If there are any transmission experts out there I need some advice.  I want the right parts/upgrades to make this transmission as bullet proof as possible so here goes.
The truck- My 1985 C30 with a stock 350 engine, currently a TH400 and either a very low rear (supposed to be a 4.56)
I want a transmission that I can tow with if needed.  I want firm shifts but nothing that would chirp the tire under full throttle.  The research of shift kits, shift correcting kits, special this and that is making my head hurt so I am asking those who know to put together everything I would need to do this right.
I haven't looked at the carb or throttle cable bracket to see if it is set up for a TV cable or not.  I am also leaning toward an adjustable vacuum switch for the lock up to get away from the electric unless it is not recommended.  I will have my gear ratio and tire size before I meet the man to make sure I will have the proper speedometer cable drive and driven gears.
Talking on the phone this guy seems to know his stuff but I would like to have a list to hand him that I want done to it.  He is a transmission re-builder of 25 years and can build me one for $600 with a new Torque convertor supposedly and give me a 1 year unlimited mile warranty.  He is about 10 miles from me and said he would adjust the TV cable properly...
Thoughts/insight/wisdom?  Thanks in advance
Offline mpullen66
Re: 700R4 rebuild... what to ask for???
« Reply #1 on: December 22, 2011, 08:46:42 pm »
I had my sons 700r4 rebuilt about 6 months ago. My son can tear up an anvil with a plastic spoon. So the tranny shop put in a  corvette servo, believe corvette valve body, and the "sunshell" was replaced with one called "The Beast". It also has a some type of shift kit.  Its holding up so far and runs great.
Mike
1987 LWB,2WD,350,700R4  times 2
Offline muddpuppy01
« Reply #2 on: December 22, 2011, 08:53:32 pm »
sounds like a good deal if he really is replacing the hard parts to upgrade it. just dont forget about the evtra cost with swapping the tranny out. new dipstick, tv bracket, vacuum switch, wiring harness, drive shaft work, and the tv cable itself.
here was list that mine had done
 PRECISION MASTER OVERHAUL KIT
 SUPERIOR HIGH PERFORMANCE REPROGRAMMING SHIFT KIT
 SUPER PUMP
 DIRECT/REVERSE INPUT DRUM
 TURBINE INPUT CLUTCH HOUSING
 MODIFIED SUNSHELL DRIVE GEAR TO INCREASE REAR PLANETARY LUBRICATION
 MODIFIED INPUT SUN GEAR TO INCREASE FORWARD PLANETARY LUBRICATION
 UPDATED/MODIFIED ACCUMULATORS
 HIGH PERFORMANCE BAND
 UPDATED & MODIFIED GOVERNOR w/SPRING KIT & NYLON GEAR
 RECALIBRATED VALVEBODY w/UPDATE TV VALVE ASSEMBLY
 RECALIBRATED VALVE PLATE FOR SHIFT FIRMNESS
 NEW HIGH FLOW FILTER
 NEW LOW/REVERSE HEAVY DUTY SPRAG
 NEW HEAVY DUTY FORWARD INPUT SPRAG
 NEW HIGH PERFORMANCE ALUMINUM SERVO
you can buy the parts from them for under $500
http://www.monstertrans.com/store/products/700R4-Rebuild-Kit%2C-Mega-Monster%252dIn%252dA%252dBox%3A-1987%252d93.html ( note I am just a happy customer )
« Last Edit: December 22, 2011, 08:59:15 pm by muddpuppy01 »
Offline mikek20
« Reply #3 on: December 23, 2011, 09:05:51 am »
I agree with the monster transmission suggestion. Im going to be having monster trans build mine. And besides what they sell, you can email them and ask for special builds. I told one of the techs about my motor, tire size,  front and rear gears , and my intended use of tranny. The tech was great with getting back to me and giving several build options with different prices. I reccomend you look into them.
« Reply #4 on: December 23, 2011, 03:47:24 pm »
For what you are doing,
Sunshell, Servo, reprogramming kit, pump modifications, new converter & rebuild kit will get you by just fine.
