Author Topic: Getting water in the cab on the right side floorboard  (Read 3631 times)
Offline superior82
« on: January 01, 2012, 06:18:03 pm »
I have a 1982 Chevrolet C20 that I bought from a friend a few months ago.  I yanked out the original vinyl floor mat and found rust on the passenger side floor.  I pulled kick panel that has a rubber flap with a vaccum tank on the passenger side and discovered the water was dripping through the oval opening.  I popped the hood and after some time I finally found out that the water is getting into the rubber where the hood hinge bolts to the firewall and dripping into the cab.  I got a new gasket from   for the oval opening on the inside of the cab where the rubber flap goes.  I just dont think that water should be running down through there.  What should I do?
« Last Edit: January 01, 2012, 10:57:48 pm by Blazin »
God Bless John Wayne
Offline superior82
Re: Getting water in the cable on the right side floorboard
« Reply #1 on: January 01, 2012, 06:21:16 pm »
Im getting water in the cab on the right side floorboard!  I can't believe I did that.
« Reply #2 on: January 01, 2012, 06:58:32 pm »
There is a bulletin on this. I've posted it on here before if you try using the search function. I'll see if I can dig it up too
http://forum.73-87chevytrucks.com/smforum/index.php/topic,22630.0.html
« Last Edit: January 02, 2012, 12:54:30 pm by Captkaos »
