Author Topic: I need a measurement please.  (Read 3528 times)
Offline klaussk
« on: January 04, 2012, 11:29:44 am »
I am currently on deployment and I wanted to make a velocity stack for my carb and air cleaner. But I forgot to take the measurements when I was home on leave. I just need  the inside and outside diameter of the seat for the air cleaner on top of the carb. Its a 4160 holley 600 cfm. the same size that the stock quadrajet uses. So measuring either one would work for me. Thanks guys. I really appreciate anyone who will take these measurements for me. Its my deployment project. I need to raise the air cleaner because  I am going to build a ramair hood.
Go ahead hit it with a hammer. Theres only one level of broke.
Offline ehjorten
Re: I need a measurement please.
« Reply #1 on: January 04, 2012, 01:38:11 pm »
I've got both!  Can take that measurement for you when I get home tonight.
-Erik-
Offline klaussk
« Reply #2 on: January 04, 2012, 09:27:06 pm »
Thanks man. I appreciate it.
Offline ehjorten
« Reply #3 on: January 05, 2012, 07:20:53 pm »
Inside diameter is 5" and the outside diameter is 5-1/2".  Sorry for the day delay!
-Erik-
Offline klaussk
« Reply #4 on: January 05, 2012, 08:49:07 pm »
thats great. Thank you very much. And that just so happens to be the perfect size to use a section from a 5 inch shell. they taper out towards the bottom ever so slightly. So I should be able to cut a perfect peice for it.
« Reply #5 on: January 05, 2012, 08:55:11 pm »
5 1/8" is standard measurement
