Author Topic: SHIFT LINKAGE /HEADER ISSUE...  (Read 10817 times)
Offline frotosride
    • WFO CONCEPTS
« on: March 01, 2012, 06:07:07 pm »
Need a little advice. I just put my flowtech on and i took it for a spin with open headers on....sounded awesome, well i'm sure my neighbors didn't think so. The problem is my shift linkage is rubbing on one of the tubes. I reallu don't want to break out the BFH and ding up my brand new headers...Anyone have any suggestions on other ways to get the clearance I need.  350/700r4.
Offline firefighter
Re: SHIFT LINKAGE /HEADER ISSUE...
« Reply #1 on: March 01, 2012, 10:40:02 pm »
I was just working on my shifter linkage tonight so I know how close this can be.
If you don't want to touch the new headers (and I don't blame you), you may have to modify your linkage a little bit.
You really don't want to modify it too much or you'll mess up the geometry of it. How much it it interfering?
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: March 02, 2012, 12:07:06 am »
I haven't actually gotten my hands dirty on them yet. I just glanced up behind the rear tire to see wht it was hard to shift.. and thus the problem. Maybe it will be simpler than i'm thinking once i getr into it.
« Reply #3 on: March 02, 2012, 08:19:26 am »
Are you sure you didn't just knock it loose from the frame?
Offline Grim 82
« Reply #4 on: March 02, 2012, 08:29:33 am »
When I had the automatic in mine, I had to straighten the bend in the middle of the linkage rod, and bend the top of it a little tighter and then take up some slack at the slide adjuster on the bottom to get it closer to the firewall. That was with hooker headers.
Offline frotosride
    • WFO CONCEPTS
« Reply #5 on: March 02, 2012, 02:55:06 pm »
No I'm not sure if I did or not but when we get out of the hospital I'm going to check and make sure.
Offline frotosride
    • WFO CONCEPTS
« Reply #6 on: March 02, 2012, 02:56:42 pm »
Thsi si what I think I will habe to do. It looked like I only have to clear ont tube and that should be easy. I just hope I don't have to take the headers off again...
Offline frotosride
    • WFO CONCEPTS
« Reply #7 on: March 06, 2012, 01:09:31 am »
Got it figured out. It took all of about 3 mins and that includes both attemps. All I ended up doing is slightly bending the linkage that comes out of the column where the rod connects. Just FYI...'87 TBI runns a little rough with open headers even with the os sensor in place. Oh, and of course I took it around the block at 930..sorry to al those living in th eimmediate area of Finley,TN I tried to keep my foot out of it...TRIED!!!
Offline frotosride
    • WFO CONCEPTS
« Reply #8 on: March 06, 2012, 01:12:14 am »
Oh, one more thing to put in the "don't forget this" section of mental notes....DIP STICK!!! You don't realize it is missing for the first few minutes and I do mean few.. ;D
« Reply #9 on: March 06, 2012, 04:34:20 pm »
Liar
Offline frotosride
    • WFO CONCEPTS
« Reply #10 on: March 18, 2012, 12:03:59 am »
Ok so you busted me...I'm not sorry at all. I love the sound of those open header notes pinging off every house and car as I drove by...oh well.
