Author Topic: th350c rebuild  (Read 12905 times)
Offline 305chevy c-10
th350c rebuild
« on: April 04, 2012, 10:48:48 pm »
i think i have a th350c trans .there it a plug on the driver side above kickdown .i never knew it had a lockup and don't really know if it was even hooked up .my question is whats it for ?do i need it hooked up ?how do i hook it up ?does it function differently than a th350 ?for instance putting my trans in 1and standing on it will it auto shift to 2 or will i have to manual shift it .also how will this lock up work with a 2500 stall .
Heartbeat of America yesterday's cheverolet
18T5C10
Re: th350c rebuild
« Reply #1 on: April 05, 2012, 06:36:38 am »
     If I remember correctly (if not someone will correct me), the C version was the electronic lock up version so it could lock in a gear, if you put it in first it stays in first.  The 1 thing I am not positive is if there was a rev limit on it, so if you over rev'd it, it would shift and not hurt the trans.
    Someone else will chime in I am sure.
Offline jaredts
Re: th350c rebuild
« Reply #2 on: April 05, 2012, 07:45:34 pm »
I don't know much about th350c's, but the lockup torque converter will help a lot with fuel economy.  It eliminates slip when you don't need slip (cruising in 3rd).  Working properly, you don't have to do anything different when driving.  It has nothing to do with your transmission changing gears.  If you can get what you have working or verify that its working, you just need to make sure to get a tc that is compatible.
Offline TexasRed
Re: th350c rebuild
« Reply #3 on: April 05, 2012, 08:15:25 pm »
yeah th350 torque converters and th350c torque converters are different. the th350c much more $$$
Re: th350c rebuild
« Reply #4 on: April 05, 2012, 08:37:36 pm »
On the drivers side above the kickdown? Whatchu talking bout Willis?
Re: th350c rebuild
« Reply #5 on: April 05, 2012, 10:23:47 pm »
ok that confirms it them ,i can't find the mv4 and other codes on the trans to confirm that its a th350c but i do have a plug with 3 wires running to it .i have to admit im kinda fustrated now because i have the lock up .my cam(howards 180305-08 ) calls for a 2500 stall ,but the lock up tc cost almost 2x what non lock up does .never knew there was a such thing as a 350c. found that out after i bought the cam and was about to get the tc .whats the down side to not getting the 2500tc with this cam
18T5C10
Re: th350c rebuild
« Reply #6 on: April 07, 2012, 09:48:30 am »
Just use the stock converter for now.
Re: th350c rebuild
« Reply #7 on: April 07, 2012, 01:31:44 pm »
how will it affect my engine performance
18T5C10
Re: th350c rebuild
« Reply #8 on: April 07, 2012, 03:35:32 pm »
this is a pic of my thans .is this the plug everyone is refering to on the driverside.does anyone know what the stock stall for these trucks are 15-1800 maybe or is it less
18T5C10
Re: th350c rebuild
« Reply #9 on: April 07, 2012, 10:18:17 pm »
Thank you for the picture.  I actually had that trans in my 85C10 that 2nd gear was out... (and didn't know it) now a 700R4 is in there.
Re: th350c rebuild
« Reply #10 on: April 07, 2012, 11:55:03 pm »
does anyone know where that  plug go to ? i know it controls lockup.someone said its wired into the brake to activate and deactivate lockup .im clueless
18T5C10
Re: th350c rebuild
« Reply #11 on: April 08, 2012, 07:01:35 am »
search tcc or torque converter clutch on here. Plenty of info
