Author Topic: 88 suburban square body tilt front end  (Read 65812 times)
Offline wildcatjason
Re: 88 suburban square body tilt front end
« Reply #30 on: May 05, 2012, 09:39:50 pm »
I actually got further then this, but it's to dark to take pictures.
« Reply #31 on: May 07, 2012, 01:38:59 am »
I am thinking about using Aerocatch on mine WHEN I get back to it.
http://www.aerocatch.com/aerocatch
Well captain, I bought some of those on eBay. I think its to good an idea to pass up.
« Reply #32 on: May 07, 2012, 01:58:22 am »
A little eye candy.
« Reply #33 on: May 08, 2012, 09:38:23 pm »
Did a lot a sanding a priming today. This was the first coat of primer. I've sanded and added a couple of other shots of high fill primer.
I am putting a wastegasted 12cm housing on my H1C. I hope it clears the heater box and ac unit.
« Reply #34 on: May 09, 2012, 02:18:39 pm »
I got in some pretty cool parts today and the engine set back in the bay. I'm calling it quits until Sunday. I'm tired and still gots ta go back ta work....blah.
« Reply #35 on: May 09, 2012, 08:33:41 pm »
Nice progress!
« Reply #36 on: May 11, 2012, 05:21:53 pm »
So pretty!
« Reply #37 on: May 12, 2012, 12:43:28 pm »
     It will be nice to see it completed, especially seeing it all tore apart the steps you went through.
« Reply #38 on: May 13, 2012, 10:29:05 pm »
The engine is back in and I had to heavily modify the exhaust manifold or lose the wastegate. I wanted to keep it in case I have any surge issues.
« Reply #39 on: May 15, 2012, 07:08:40 pm »
Battery relocation.
« Reply #40 on: May 21, 2012, 12:42:28 pm »
Nice work!  And you got the Aerocatches!
« Reply #41 on: May 25, 2012, 01:48:47 am »
A little update. Went a different route with the turbo. He341. I did get the latches. Don't have them on yet.
4 in exhaust. That is a separate pump for the intercooler from a mustang. I am running a tranny cooler and a dirt bike radiator for the intercooler. Electric fan from a taurus.
« Reply #42 on: May 28, 2012, 10:44:50 pm »
I only have 4 inches of space between the inlet of my turbo and the oil filter. Instead of coughing up 200 bucks for an remote oil kit. I am building this out of fiberglass. I made it as wide as I can to keep it free flowing. I started with a 4 in drainage pipe and it like this.
Used my wife's hot glue gun. Started shaping this floral foam. She went and got it for me a local hobby shop.
This stuff will mold into anything you want with a dremel and a high speed disc sander.
Started laying fiberglass over the foam.
q
« Reply #43 on: June 04, 2012, 07:39:15 pm »
my hood pins installed.
« Reply #44 on: June 05, 2012, 07:16:39 am »
     I really like those hood pins, great choice.
