Author Topic: why does my truck run the way it does?  (Read 18133 times)
Re: why does my truck run the way it does?
« Reply #15 on: April 18, 2012, 08:18:16 pm »
tune it up and set the timing.
Offline rusty but trusty
« Reply #16 on: April 19, 2012, 05:40:37 pm »
yes the service engine soon light comes on and how would i go about doing a tune up? yes this is a dumb question but i really don't know much. and thanks too all of you
87 GMC V1500 305 700R4 NP208 and 10 bolts front and rear
« Reply #17 on: April 21, 2012, 11:50:34 am »
Replace the spark plugs, wires, cap, rotor, fuel filter, air filter PCV valve, set the timing, disconnect the negative battery cable for a minute to reset the adaptives.
« Reply #18 on: April 23, 2012, 07:07:45 pm »
ok iv done oil change new cap and rotor and new wires new plugs new fuel and air filters but i cant find my pcv valve all of my breather lines on my valvecovers go to my intake manifold
« Reply #19 on: April 23, 2012, 07:31:52 pm »
The PCV valve should be at the end of a 3/8" vacuum line plugged into the top of a valve cover.  Since your engine has been replaced, it could be either side.
« Reply #20 on: April 24, 2012, 07:36:07 pm »
     You might only see the top black part of the PCV valve, the silver part might be pushed into the rubber grommet.
« Reply #21 on: April 25, 2012, 03:23:42 pm »
bake74 thank you so much i have looked and looked and then i read your post and i felt kinda dumb but enlightned
« Reply #22 on: April 26, 2012, 06:59:43 am »
     So does that mean it is there, but just pushed in the grommet ?  If so you are welcome, that is what we are all here for, just to help without judgements. ;D
« Reply #23 on: April 26, 2012, 03:30:47 pm »
the pcv was pushed into the valve cover so bake74 saved the day.
does anybody have any idea why the engine would shake more than is reasonable at idle, the throttle response isn't great either
Offline 454Man
  • Why Race?
« Reply #24 on: April 26, 2012, 03:36:51 pm »
Hook up a vacuum gauge and that will let us know what it reads. They are cheap to buy. I keep one hooked up inside my cab.
Offline Donut
« Reply #25 on: April 26, 2012, 04:54:36 pm »
Misfiring or crossed plug wires?  Incorrect timing?  Spark plugs loose?  Distributor cap not locked down?
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
« Reply #26 on: April 27, 2012, 05:43:27 am »
     Also, check the motor mounts to see if they are shot.
« Reply #27 on: April 28, 2012, 03:28:22 pm »
OK i have 17 inches of vacuum and the plugs, plug wires and rotor and cap are brand new the cap is tight and the coil is a month old also # 1 is always wet but defiantly has spark
« Last Edit: April 28, 2012, 04:09:58 pm by rusty but trusty »
« Reply #28 on: April 29, 2012, 12:00:02 pm »
      Not that is has any thing to do with the truck shaking, you said #1 spark plug is always wet.  With oil or just moister ?
« Reply #29 on: April 29, 2012, 07:49:27 pm »
wet with gas and #8 was also wet with gas  so i switched them but i think iv just lost my firing order completely
« Last Edit: April 29, 2012, 07:57:35 pm by rusty but trusty »
