Author Topic: What is this?  (Read 10544 times)
Offline Shawn0331
    • My Blog
What is this?
« on: May 12, 2012, 10:36:46 pm »
Ok, so while I was under my truck today, I found something by the oil filter that looks like it has a crack in it...kinda worried about it. Should I be freaking out?
1987 Chevy V10 Silverado SWB 5.7 on 33x12.5's
http://www.shawnseeley.com
Re: What is this?
« Reply #1 on: May 12, 2012, 10:46:39 pm »
     I see the crack, but not clear what is cracked.  If that is the bell housing for the transmission(it looks to be the bell housing, just not sure from the pics) it has no oil in it(except in the torque converter if it is an auto).  If it is part of the actual transmission, I would be worried.
Re: What is this?
« Reply #2 on: May 12, 2012, 11:28:06 pm »
It's the torque converter shield. I'd be more worried about all those leaks
Offline Shawn0331
    • My Blog
Re: What is this?
« Reply #3 on: May 13, 2012, 12:36:12 am »
Thanks.
I'll wipe everything down underneath on Monday and take it for a spin to see if I can tell where it's leaking. It's always raining up here and I have a hard time telling with all the mud that splashes up underneath on our unpaved road.
Re: What is this?
« Reply #4 on: May 13, 2012, 12:40:46 am »
driving it can cause the air to push the oil into other places. try to see where it is leaking from before you drive it
Re: What is this?
« Reply #5 on: May 14, 2012, 11:11:17 pm »
Thats doesn't look like its cracked, it is cracked! Easy enough to swap. Three bolts up each side, and the two that hold the braces on that run up behind the motor mounts.
Offline Psycho71
Re: What is this?
« Reply #6 on: May 15, 2012, 04:17:16 pm »
He just has self changing fluids. Just add more when it needs it.
Re: What is this?
« Reply #7 on: May 16, 2012, 02:26:03 am »
plus mud tends not to stick to oil that well
Offline thirsty
    • Suitor's Garage
Re: What is this?
« Reply #8 on: May 16, 2012, 06:23:31 am »
This is true. When I used to go mud bogging I would oil everything under my truck. A day or two later the mud would start falling off then I would spray it with water and it would be clean again. It made it real easy to clean.
Offline Shawn0331
    • My Blog
Re: What is this?
« Reply #9 on: May 16, 2012, 10:38:57 am »
I cleaned a lot of the oil off using brake cleaner and a rag. Hasen't shown any new leaks. Probably from the previous owner.
