Author Topic: 67 c10 3 speed set up  (Read 22661 times)
Offline hotrod24
Re: 67 c10 3 speed set up
« Reply #15 on: July 31, 2012, 02:15:14 pm »
So you are saying that it would be a simple swap?
1978 pontiac grand prix...
Offline hotrod24
« Reply #16 on: July 31, 2012, 02:46:27 pm »
Heres a pic of the mounts i have now...
« Last Edit: July 31, 2012, 02:50:26 pm by hotrod24 »
« Reply #17 on: July 31, 2012, 02:50:00 pm »
Yes you have the same blocks so everything should work.  Just use the engine mounts from your old engine
« Reply #18 on: August 01, 2012, 09:14:42 pm »
Having the mounts on the motor is a plus, it should drop right in place unless you had a V8, in that case you will need to move the engine stand mounts to the I6 location.
Offline hotrod24
« Reply #19 on: August 02, 2012, 03:02:34 pm »
I have a 250 inline 6 right now...
« Reply #20 on: August 02, 2012, 05:23:46 pm »
It should drop right in then.
Offline hotrod24
« Reply #21 on: August 02, 2012, 06:05:08 pm »
Will the starter from my 80s motor bolt to the 67s block?
Offline hotrod24
« Reply #22 on: August 06, 2012, 07:02:10 pm »
OK how do i make the 67s throttle linkage work on my 80?
« Last Edit: August 06, 2012, 07:35:07 pm by hotrod24 »
« Reply #23 on: August 06, 2012, 07:16:22 pm »
Post a picture on how the 80 cable linkage looks...
Offline hotrod24
« Reply #24 on: August 07, 2012, 11:39:11 am »
Here ya go...
« Reply #25 on: August 07, 2012, 12:37:14 pm »
How I would do it... obtain a V-8 throttle cable and bracket off a quadrajet and fabricate the mount to work.
Offline hotrod24
« Reply #26 on: August 07, 2012, 01:47:48 pm »
That sounds like a plane but i dont have a welder.  I just need this linkage to work for now because i am going to upgrade in the future. Here is some pics of what i should have...
« Reply #27 on: August 07, 2012, 01:59:52 pm »
Any 250 I-6, 1973 on up until the integral head should be what you need...
Offline hotrod24
« Reply #28 on: August 07, 2012, 02:22:09 pm »
Would that be better to just get the linkage i need or make my on?
« Reply #29 on: August 07, 2012, 02:39:12 pm »
Depends on how comfortable you feel with making it work.  You don't want it to bind or stick so OEM is the "right" way to go.  If you plan on a SBC in the future you will at least have the right cable.  I wouldn't imagine it would take much to make it work right but the air cleaner housing has to clear as well.
