Author Topic: Tranny pan issues  (Read 7168 times)
Offline Nurchburgler
Tranny pan issues
« on: December 31, 2012, 07:05:26 pm »
So, I am changing my tranny pan on my th350.
Everything seems to be going fine except I can't figure out how to get the two screws behind the cross member out.
Is there a tool or do I have to remove the cross member?
I tried 1/4 drive knuckle with 1/2 socket..was so close..but no luck.
Thanks for the help fellas
Offline bigchevyc30
  • the pig
Re: Tranny pan issues
« Reply #1 on: December 31, 2012, 07:59:07 pm »
well depending on how much space u have u could use a extension or use a u-joint extension to get to it if not i would think you would have to then unbolt the crossmember
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Tranny pan issues
« Reply #2 on: December 31, 2012, 09:00:23 pm »
Yeah the problem is the actual socket fitting.
I looked on some other forums and found that I can unbolt the two bolts connected to the tranny and use a jack to slightly lift the tranny to make that 1/36 of and inch I need.
I am going to continue this tomorrow
« Reply #3 on: January 01, 2013, 11:38:56 am »
     Find a way to support the TRANS, not at crossmember.  Then loosen crossmember, take pan off and replace, then tighten crossmember back up.
« Reply #4 on: January 01, 2013, 11:49:53 am »
"usually" in those situations the trans mount has compressed (deteriorated) to the point that getting to the rear bolts are next to impossible.  Might I suggest replacing the mount while you are under there...
Tranny pan issues
« Reply #5 on: January 01, 2013, 05:47:33 pm »
Fixed it...took cross member off.
However..found the leak
The circle in the back of pic is leaking..what is that?
Looks like something is missing?
Please excuse my lack of knowledge.
« Reply #6 on: January 01, 2013, 06:33:31 pm »
Servo cover. You need to clean that all up and degrease it before you pull anything apart. You should also replace your transmission mount.
« Reply #7 on: January 01, 2013, 07:46:58 pm »
X2 on the above. I have also trimed a 3/16" off the cross member in the past to help ease the removal the next time.
Tranny pan issues
« Reply #8 on: January 01, 2013, 08:05:50 pm »
Ok
Looked up servo and it seems pretty easy to fix, however I am having trouble finding the correct parts to order..jcwhitney has 4 listed..none of which say th350..jegs and summit neither..
Any ideas?
Thanks
Accumulator servo?
« Reply #9 on: January 02, 2013, 01:34:45 pm »
Gonna swing by a transmission shop and see what I can find out.
« Last Edit: January 02, 2013, 05:43:03 pm by Nurchburgler »
« Reply #10 on: January 02, 2013, 08:24:49 pm »
Look under intermediate servo or accumulator
Tranny pan issues
« Reply #11 on: January 02, 2013, 11:31:05 pm »
I found it at tsr..they have an exploded diagram..thanks though.
Gonna change the cover and gasket and go from there. ( actually add the cover lol) missing! weird.
Tranny pan issues
« Reply #12 on: January 06, 2013, 05:01:04 pm »
Got it fellas.
Accumulator cover gasket has a nick in it. No more leaks yahooooooo!
Drives great..now to brakes
« Last Edit: January 06, 2013, 06:58:31 pm by Nurchburgler »
« Reply #13 on: January 07, 2013, 09:32:48 pm »
Got it fellas.
     Glad to hear it.
Tranny pan issues
« Reply #14 on: January 13, 2013, 11:04:40 am »
Found another leak... On the cooler lines..small drips...will investigate this week.
