73-87 Chevy & GMC Trucks
Heator Hose Connection
Topic: Heator Hose Connection (Read 6378 times)
altuschevy86
New Users
January 23, 2013, 12:31:58 pm »
Installed heater core on 86 Chevy C10 that wasn't connected, need instructions on where to connect heater hose, to the engine block or water pump.
bd
Re: Heator Hose Connection
January 23, 2013, 12:47:33 pm »
Take a look at this example...
Illustration of heater hose routing
If you don't have the heater hose connection to the radiator, the 3/4" hose will connect to a fitting threaded into the top of the water pump. The 5/8" hose connects to an intake manifold fitting located either at the right front or right rear, depending on model configuration.
altuschevy86
New Users
January 23, 2013, 02:00:40 pm »
Thanks for the picture, found that after I posted this.
