Author Topic: Heator Hose Connection  (Read 6381 times)
Offline altuschevy86
  • New Users
« on: January 23, 2013, 12:31:58 pm »
Installed heater core on 86 Chevy C10 that wasn't connected, need instructions on where to connect heater hose, to the engine block or water pump.
Offline bd
Re: Heator Hose Connection
« Reply #1 on: January 23, 2013, 12:47:33 pm »
Take a look at this example... Illustration of heater hose routing
If you don't have the heater hose connection to the radiator, the 3/4" hose will connect to a fitting threaded into the top of the water pump.  The 5/8" hose connects to an intake manifold fitting located either at the right front or right rear, depending on model configuration.
  • New Users
« Reply #2 on: January 23, 2013, 02:00:40 pm »
Thanks for the picture, found that after I posted this.
