Author Topic: temp and oil pressure gauges not working  (Read 3954 times)
Offline mikesantos
« on: February 13, 2013, 12:23:19 am »
when I bought my truck about a week ago, the temp and oil gauge are not working.  they just sit there.  where would I begin to diagnose the problem? kind of a newbie at this.  thanks ya all
Coleen - 1995 Cheyenne
Amber - 1983 - C10 Custom Deluxe
Re: temp and oil pressure gauges not working
« Reply #1 on: February 13, 2013, 10:33:02 am »
     There is a thread on checking the gauges in the tech section by bd I believe.  You can start there, then I would check the sending units to make sure both are good and possibly that they are indeed hooked up and the wiring is good ( not shorted or cut, etc. etc ).
Offline andystaiger
« Reply #2 on: February 13, 2013, 06:44:58 pm »
Considering everything is hooked up properly and you have electric sending units; You can just take a wire and ground out your sending units..
If they top out; then your sending unit is bad..
Otherwise it's your gauge.
