Author Topic: subwoofers  (Read 11999 times)
Offline rewardedgamer
subwoofers
« on: November 29, 2013, 05:33:24 pm »
i was wondering if anyone has dual 12 inch subs in there truck and could give me some ideas on how to fit them if you have pictures that would be amazing. thanks
Re: subwoofers
« Reply #1 on: December 01, 2013, 06:23:25 pm »
Under the seat
Offline 454Man
  • Why Race?
Re: subwoofers
« Reply #2 on: December 01, 2013, 07:21:41 pm »
I just made one box for a 10 inch. It has .862 volume inside. Anyone Wanna guess the size? Will say this it fits behind the seat (seat all the way back) with An inch out more space between. The box and seat.
Offline rich weyand
Re: subwoofers
« Reply #3 on: December 01, 2013, 08:40:39 pm »
Two 12" subs would be tough, at least if you got beefy ones and not something cheesy.
Why the spec for two 12" subwoofers?  Do you want the size or the performance?
I put an ultra slim 8' powered subwoofer in the truck and love it.  I have a write-up in this sub-forum about the install.
Depending on your budget, you could use a couple of these, or a 10" super slim, or even a pair of 10".  They run right off the head unit.
http://www.lanzar.com/products/Car-Audio/Subwoofer-Enclosures/Amplified-Enclosures
Offline 81_Chevy
Re: subwoofers
« Reply #4 on: December 02, 2013, 09:43:46 am »
hop over to my build thread. ive got two 12 inch subs behind my seat right now. They are shallow mount ones from a home theater system i snagged off a buddy. also go in the search box and type in sub woofer and you will see another thread from me and it has two or three different kinds of shallow mounts subs that will fit in our truck.
im probably going to go with the pioneer 12inch shallow pre loaded enclosure for my next upgrade.
Re: subwoofers
« Reply #5 on: December 02, 2013, 12:18:21 pm »
i like really loud bass lol... thats why i want some really good 12s and i was thinking about the square not round ones
Offline 454Man
  • Why Race?
Re: subwoofers
« Reply #6 on: December 02, 2013, 01:30:00 pm »
Do you mind not having the seats all the way back? The main things of concern are having the proper air space in front of the woofer and the correct cubic ft. Inside volume for the woofer to perform like it was designed.
Re: subwoofers
« Reply #7 on: December 02, 2013, 07:26:03 pm »
well i kinda need it all the way back im 6'6 so... and if you asking as far as engine goes its got a Chevrolet Performance 350 290 hp with about 600 miles on it
« Last Edit: December 02, 2013, 07:27:40 pm by rewardedgamer »
Offline 454Man
  • Why Race?
Re: subwoofers
« Reply #8 on: December 02, 2013, 07:57:22 pm »
Don't mind that... Its my sig on Tapatalk :-). Do you have bench seats?
Offline rich weyand
Re: subwoofers
« Reply #9 on: December 02, 2013, 08:35:33 pm »
You might be able to get a pair of these in.  Might have to round the corners a bit, or take off the carpet where they meet in the middle to get them in between the curves of the cab corners.
http://www.speakerboxesusa.com/sub-boxes-woofer-manufacturer-shallow-mount/
Re: subwoofers
« Reply #10 on: December 02, 2013, 09:56:27 pm »
oh lol i feel stupid now lolz... yea i got a bench seat
Offline 454Man
  • Why Race?
Re: subwoofers
« Reply #11 on: December 03, 2013, 09:20:27 am »
Nooooo worries :-).
I used this sub box calculator to get the volume I wanted.
http://www.bcae1.com/spboxnew2.htm  my box measures top depth 3in, bottom depth 7.5in, width is 56in., Back height of 15in.
I choose this sub
http://www.sonicelectronix.com/item_27194_Precision-Power-PPI-A.10.html
Should have a good out put with my kicker amp... IM thinking of cutting the material on the back of the seat to allow more air flow. Everyone knows speakers need air space :-)
« Last Edit: December 03, 2013, 09:22:46 am by 454Man »
Offline 454Man
  • Why Race?
Re: subwoofers
« Reply #12 on: December 03, 2013, 09:29:42 am »
The size and cubic in volume of my box will give you Ann idea of why I chose a 10 and not a twelve or two 10s/ 12s. I wanted my seat all the way back for space and comfort. Try building the correct box size (typically 1.25 cubic in. Sealed box) if you can slide the seat back all the way I'll get the same setup :-)
« Last Edit: December 03, 2013, 02:19:16 pm by 454Man »
Offline lvnloud28
Re: subwoofers
« Reply #13 on: December 06, 2013, 09:23:54 am »
i have a 84 and i have 4 10" kicker cvt's behind my seat and my seat is all the way back and it jams and have all my amps under the bench seat.
Offline chevyjoe_99
Re: subwoofers
« Reply #14 on: December 20, 2013, 10:53:05 pm »
I know I'm a little late to the party but, if you're still considering 12's, look at the Alpine type E subs. The mounting depth is 5" and recommended box size is .65 - 1.0 cubic feet. I have one in my daily driver which is an f150 super crew and it sounds awesome.  I was able to build a custom box to fit under the rear seat in my f150 and it fits behind the seat of '80 high sierra. I had the old type e and the depth on it was 8 1/4" so look for the black cone, not white.
'80 K25 High Sierra, 7" lift, 36x14.50R16.5 Swampers, mildly built 400 small block, sm465 4spd
