Author Topic: SUSPENSION EMERGENCY:  (Read 5337 times)
Offline Stewart G Griffin
« on: September 10, 2006, 03:21:00 pm »
Please view the following document:
Is fig.a part of the control arm or is it part of the actual ball joint?
This is an 83 c-10 2WD.
Edited by: Stewart G Griffin at: 9/10/06 2:22 pm
Offline 123 pugsy
Re: SUSPENSION EMERGENCY:
« Reply #1 on: September 10, 2006, 08:02:00 pm »
Its part of the balljoint. If you look at your new one,you will see it.
Pugsy
76 C10 LWB
TPI 350
« Reply #2 on: September 10, 2006, 10:49:00 pm »
OK, i got it out and pressed the new one in.
Next:
1) How to lube balljoints?
2) How often?
3) What type of grease?   (please be brand specific as well)
« Reply #3 on: September 11, 2006, 05:00:00 am »
You should have gotten a grease fitting with your new ball joint. Use a grease gun and grease it with any high temp chassis wheel bearing grease.
Offline RSBAD454
« Reply #4 on: September 12, 2006, 10:32:00 pm »
there should be a threaded hole on bottom of Ball Joint to screw a zerk fitting in.
Toys are my game
http://
