Author Topic: Resto almost done, extra wires (engine harness)  (Read 12437 times)
Offline Tonka
« on: January 26, 2014, 07:35:26 am »
About done with the resto on my 77 K15. Using a wiring harness off an early 80's no A/C 2wd Chevy. Everything is about plugged up at this point but we still have:
Thick Orange wire (10 or 12 gauge wire)
Skinny Green
Skinny pink (this wire is long)
Tan (propertioning valve?)
Also a plug with 3 wires coming out of it- Pink or orange with white stripe, a black wire and a dark green or dark blue colored wire.
Where do these wires go? THANK YOU!!!!
Re: Resto almost done, extra wires (engine harness)
« Reply #1 on: January 26, 2014, 08:57:33 am »
     There might be several wires with those colors you are talking about.  Things we need to know so that we can help you.
     1:  Where do the wires you are talking about generate from ? ( fuse block, front engine connector block, etc. ).
      See here if you need to pin point a certain wire.   http://forum.73-87chevytrucks.com/smforum/index.php?topic=11766.msg87585#msg87585
     2:  The 80 truck that you are using the wiring harness from, how is it different from yours, ex. 80's had electric choke and yours does not.  Cruise installed and yours does not. etc.etc.  Anything different will make a difference in wiring.
     3:  The wires you are describing, do they look factory installed, or do they look like someone else installed them ?
     Since you are not comparing apples to apples, but a apple to a orange, it is all in the details.  The more detail you can be, the better we can help you out.  If you just do not know, then asking if someone has experienced your problem is the next best choice.
     And of course, PICS ARE WORTH A THOUSAND WORDS in cases like that.
« Last Edit: January 26, 2014, 09:03:23 am by bake74 »
Offline Tonka
« Reply #2 on: January 26, 2014, 05:08:10 pm »
Bake I am so sorry I should have been a lot more descriptive on that. I meant to say all of these were on the engine wiring harness. I will get a pic.
Offline Tonka
« Reply #3 on: January 26, 2014, 09:22:27 pm »
Some pics
Offline bd
« Reply #4 on: January 26, 2014, 09:34:50 pm »
Tonka, show us the connectors at the ends of the wires, as well.  In addition, show us where they exit the loom or firewall, run in the engine compartment, etc. - anything that might make it easier to discern these wires from others with similar colors.
The tan wire with rubber pancake boot in the upper image is for the oil pressure gauge sender.
Offline Tonka
« Reply #5 on: January 26, 2014, 09:43:19 pm »
Thanks BD. We literally pulled this harness off the ground and pretty much buried with leaves. It had been out of its original truck for 4 years.  I will get some better photos tomorrow. Thank you for your help
« Last Edit: January 26, 2014, 09:46:03 pm by Tonka »
Offline Tonka
« Reply #6 on: January 27, 2014, 07:32:08 pm »
Does this pic help at all?
I'm not near the truck at the time and I'm having to get my little brother to take the pics and thanks again for your help
« Reply #7 on: January 27, 2014, 08:53:15 pm »
All of it is coming out of the engine harness.
Green should be the coolant temp, brown (tan) looks to be the oil pressure.
Compare them to this image http://www.73-87chevytrucks.com/techinfo/wiring_diagrams/77-80_SBC_eng.jpg
Offline 81GMCBILL
« Reply #8 on: January 27, 2014, 09:38:45 pm »
 i traced all my wires on my 1985 truck ( to make sure its right) before my resto. I attached the dwgs I made up in doing it, they may help you.
85 GMC K25 4X4 383/th400/np208
Offline bd
« Reply #9 on: January 27, 2014, 09:39:52 pm »
The three-wire connector plugs onto an oil pressure switch for the electric choke circuit.  I agree, the green wire is coolant temp sensor.  Show us the 'free' ends of the wires with their plastic connectors and/or terminals.  Use the diagram Captkaos posted.
Offline Tonka
« Reply #10 on: January 28, 2014, 08:49:53 am »
BD, Kaos and Bill thank you guys so much for your help. I do appreciate it.
Offline bd
« Reply #11 on: January 28, 2014, 09:58:44 am »
81GMCBILL, you put a lot of work into that diagram.  It turned out nice.
Tonka, you're welcome - don't forget the last few needed pics.
Offline 81GMCBILL
« Reply #12 on: January 28, 2014, 08:30:45 pm »
Hey TONKA in one of your pics I see you have (i think) those Halogen headlights, in saying this, do they make a big difference, are they worth it ? I was thinking of getting them.
Offline Tonka
« Reply #13 on: January 29, 2014, 08:38:51 pm »
@81GMCBill I will let you know as soon as I turn the key and lights work! It's been a 5 year frame off resto. We've changed so much it's like a whole new truck. I also used reproduction l.e.d. 31 ford tail lights on custom mounts. All of this resto was done in a muddy backyard with the exception of the paint of course.
Thanks for your help sir!
Offline 81GMCBILL
« Reply #14 on: January 31, 2014, 02:57:11 pm »
Tonka> Hey - that's great - let us know how it goes.   thanks.
