Author Topic: NP208 or NP241  (Read 22898 times)
Offline blazing816
NP208 or NP241
« on: February 26, 2014, 12:13:10 pm »
This there a huge difference between the np208 and np241??? I have heard the 241 is stronger, I was just curious how much stronger and are they a direct bolt on to our trucks (because I know some come from newer body style trucks where the shifter is on the driver side). Just curious because I can get my hands on a np241 out of a 1990 blazer (so should be passenger side) for $100 and I am curious if it is a lot better then my np208, I have in my truck for my project.
Offline 1979C20
  • Kyle Taulton.
Re: NP208 or NP241
« Reply #1 on: February 26, 2014, 12:40:32 pm »
The np241 came factory on my 89 v2500 burb, so I am assuming it is a more heavy duty transfer case. I like having it because it is "shift on the fly" you can go from 2HI to 4HI while rolling.
Offline MANCHU1-9IN
  • LINT LICKER!
Re: NP208 or NP241
« Reply #2 on: February 26, 2014, 01:14:50 pm »
"shift on the fly" alone is worth the switch to me. I plan on doing the swap eventually, but if I found one for $100 I would pull the trigger.
"Attitude at Altitude"
2007 Silverado NNBS RCSB 4.8 LT's - UDP's - CAI - P&P TB - Vette servo - BBP tune ~ embarrassingly slow
85 K10 RCSB - 5.3l/4L80 swap - 799 heads - PAC1218's - 206/212 .553/.561 112+2.5 - BP Automotive harness - Coming together..
Re: NP208 or NP241
« Reply #3 on: February 26, 2014, 05:58:54 pm »
The 208 is shift on the fly
Offline Cabcorner
Re: NP208 or NP241
« Reply #4 on: February 26, 2014, 09:49:47 pm »
                  The 241 is geared a little lower than the 208 and considered to be an upgrade from the 208 . I wouldn't consider it a huge upgrade. Somewhere around 1990 I believe they switched to a electronic speed sensor so you may not be able to use your speedometer cable .
Offline dvdswan
Re: NP208 or NP241
« Reply #5 on: February 26, 2014, 10:09:15 pm »
IIRC, 208 is 2.6:1 and 241 is 2.72:1.  not a huge difference.
Offline blazing816
Re: NP208 or NP241
« Reply #6 on: February 27, 2014, 09:06:31 am »
Okay that's what I was reading online, ratio was a little lower and the 241 had a better oiling system. But to me I already have a np208 for my project and I know its solid. Plus I have a np208 on my "rusty but trusty" truck I drive now and it works great. Especially since I am not doing any off-roading, mostly use the 4x4 for snow here in Michigan, and every once in a while a muddy yard in the summer. Thanks for the input :)
Offline MANCHU1-9IN
  • LINT LICKER!
Re: NP208 or NP241
« Reply #7 on: February 27, 2014, 12:00:42 pm »
Ya but only at low speeds right? Below something like 15mph? As appose to the 241 shifting at any speed? That's what I thought at least.
Offline 1979C20
  • Kyle Taulton.
Re: NP208 or NP241
« Reply #8 on: February 27, 2014, 02:28:09 pm »
Im not sure on the 241 shifting on the fly at any speed, I havent tried over 15mph.
Re: NP208 or NP241
« Reply #9 on: February 27, 2014, 06:14:32 pm »
No and the 241 isn't an upgrade. The 208 is much more plentiful and cost effective as well.
Offline MANCHU1-9IN
  • LINT LICKER!
Re: NP208 or NP241
« Reply #10 on: February 28, 2014, 08:17:57 am »
Well thanks for saving me money! lol
Offline dvdswan
Re: NP208 or NP241
« Reply #11 on: February 28, 2014, 06:19:51 pm »
IIRC, CUCVs came with 208s in them as well, so there shouldn't be a question of stoutness.
