Author Topic: will they work...  (Read 7269 times)
Offline markzepp820
will they work...
« on: March 17, 2007, 04:11:00 am »
hello, I have a 79' C20.
Offline markzepp820
will they work...
« Reply #1 on: March 17, 2007, 03:39:00 am »
hello, I wanting to know if they're will be any alignment issues if I swapped my 56" rear leaf springs for some 52" 1/2 ton springs. (I know the shackles have to be moved) Do 52" & 56" springs have the same center bolt distance?Basically, when I put these 52" inch springs on my C20, the center bolt in the leaf pack should fall right in place on the perch of the axle. Wanting to know if it will all align right. thankyou
1979 C20
Re: will they work...
« Reply #2 on: March 19, 2007, 07:23:00 am »
Why? What are you trying to acheive by doing this besides allot of needless labor and effort? If you want less load carrying ability just take out one leaf from your current leaf pack.
Offline markzepp820
will they work...
« Reply #3 on: March 20, 2007, 01:13:00 am »
Your reply does not help me blazin. Your asking me a question and making a suggestion. My question is posted above. So, can someone tell me if this swap will work, without criticism preferably.
                                     thanks
« Reply #4 on: March 20, 2007, 05:24:00 pm »
MarkZepp Take a chill pill man. He wasn't saying it the way you took it just trying to better understand what and why you are doing better. If you want good advice provide good detail. So elaborate on what you are trying to accomplish a little more please.
These leafs are stacked progressively from the main leaf and a spring with a larger arc will be longer. They are interchangable but will change your ride height and load capacity obviously. If you change the shackles that will also change your ride height.
Offline roundedline
« Reply #5 on: March 20, 2007, 05:31:00 pm »
Yes, you can do that with little or no issues unless you consider your right height will drop along with the carrying capacity.
Is it possible, yes.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline markzepp820
question answered....thanks
« Reply #6 on: March 21, 2007, 12:29:00 am »
Great, thanks roundedline. I currently have 1/2 ton coil springs in the front. I removed 4 out of the 9 leafs in the back, to even out the height. (I did this a couple years ago). The rear is slowly sagging as the months go by, so thats why I want stock 1/2 ton spring packs to install in my truck. I'm not gonna use 3/4 ton leafs cause that would make my truck look rediculus.(an extreme RAKE look) Lowering my truck a little bit with these 1/2 ton suspension componets, makes it look better. I don't like the way 3/4 tons sit. Anywase...I don't make good use to the heavy duty suspension. thanks
                                                   mark
Offline markzepp820
thankyou Fast68
« Reply #7 on: March 22, 2007, 01:56:00 am »
kool, I never knew that. Thanks again for the info,
        Mark
