Electrical
ignition switch
Topic: ignition switch (Read 4064 times)
chevy2011
ignition switch
March 24, 2014, 05:56:21 pm »
does the ignition switch on a 1979 K10 custom deluxe with 3 speed on column have a accessory position on the ignition switch?
Last Edit: March 24, 2014, 06:12:51 pm by chevy2011
bd
Re: ignition switch
March 24, 2014, 06:33:13 pm »
Yes - turn the key counterclockwise from Lock.
bake74
Re: ignition switch
March 24, 2014, 07:52:43 pm »
Quote from: bd on March 24, 2014, 06:33:13 pm
You might have to push in on the key assembly a little.
74 k10, 77k10 Tom
slammed79
Thou shalt not drive stock
Re: ignition switch
March 28, 2014, 07:43:54 pm »
If you're having trouble getting into it, you might need to adjust the switch on the low side of the column.
Sent from my SM-N900T using Tapatalk
Praise the lowered
Electrical
ignition switch
