Author Topic: ignition switch  (Read 4060 times)
Offline chevy2011
ignition switch
« on: March 24, 2014, 05:56:21 pm »
does the ignition switch on a 1979 K10 custom deluxe with 3 speed on column have a accessory position on the ignition switch?
« Last Edit: March 24, 2014, 06:12:51 pm by chevy2011 »
Offline bd
Re: ignition switch
« Reply #1 on: March 24, 2014, 06:33:13 pm »
Yes - turn the key counterclockwise from Lock.
Re: ignition switch
« Reply #2 on: March 24, 2014, 07:52:43 pm »
     You might have to push in on the key assembly a little.
Offline slammed79
  • Thou shalt not drive stock
Re: ignition switch
« Reply #3 on: March 28, 2014, 07:43:54 pm »
If you're having trouble getting into it,  you might need to adjust the switch on the low side of the column.
Sent from my SM-N900T using Tapatalk
Praise the lowered
