Author Topic: The Gray Goblin  (Read 35825 times)
Offline FlatBlack77
The Gray Goblin
« on: April 24, 2014, 03:20:12 pm »
whats up guys ive been pretty inactive for the last few years here. been into other things. other cars, hobbies, life, ect. and havent been in the trucks much. i still have my 77 C10 but its in the garage on jackstands till who knows when :-\
my buddy got this '79 about 4 years ago and i told him if he ever wanted to sell it, id be there with cash. so he buys an 08 f350 and says wanna buy the Chevy? i say yes sir. $1000 later its mine.
lockout hubs
single flowmaster
homemade bed
LED tailights
toolbox mounted under bed
pretty much all there is to it.
it was running pretty bad it wouldnt idle would barely start and would pretty much just sputter its way down the road all the time lol he used it for towing here and there and as a beater truck basically. it was somebodys restoration project some years ago it had been sitting for quite awhile when he got it. the paints pretty good and the hood is the only major rust spot thats visible but look underneath and youll see some halfassed rust repairs. one of those looks good from far but far from good kinda jobs lol
i tinkered with it alot over the last few weeks and found numerous little issues and fixed just about all of them other than the timing still isnt just right and the motor/tranny/tcase mounts need replaced. spiffed it up a bit too its been fun ive got some more in store for it nothing major.
first day i got it. takin the dash apart to install some gauges
Offline FlatBlack77
Re: The Gray Goblin
« Reply #1 on: April 24, 2014, 03:21:48 pm »
new seat cover and some pics of the bed
Offline FlatBlack77
Re: The Gray Goblin
« Reply #2 on: April 24, 2014, 03:23:52 pm »
i HATED those fenders. so i got some mudlfaps from amazon put them on and cut the fenders off. much better now
Offline FlatBlack77
Re: The Gray Goblin
« Reply #3 on: April 24, 2014, 03:28:40 pm »
i changed the exhaust up a bit. punched the cat out cut the ends off and welded it over a piece of pipe and made the exit at the corner of the toolbox instead of behind the rear tire
got a set of 33/12.50/15s and im getting a nice set of factory rally wheels with rings and centers from the guy i got the truck from
painted the headlight buckets and grill. put a new bowtie on the grill and shined up all the chrome
Re: The Gray Goblin
« Reply #4 on: April 24, 2014, 07:26:47 pm »
     That's shaping up to being a pretty nice truck.  What do you have left to do ?
Re: The Gray Goblin
« Reply #5 on: April 24, 2014, 08:43:45 pm »
Looks good
Offline FlatBlack77
Re: The Gray Goblin
« Reply #6 on: April 25, 2014, 06:12:02 am »
thanks guys.
it needs some minor maintenance stuff. tranny pan gasket, front shocks, timing set, tcase mounts(doing them today), and im gunna tinker with a small handfull of other little stuff like the radio and i might end up removing the bed to install a rear sliding window then putting a removable center section in the window guard on the bed.
the tires that are on it now have good tread but they are dry rotting around the bead and the rear passenger side wheel is an odd one out of the 4. so im getting the rally wheels and mounting the 33s since it needs better tires to be safe and that odd wheel bugs the crap out of me
ive been into Hondas for the past 4 years or so its nice to get into something old again i miss these trucks
Offline FlatBlack77
Re: The Gray Goblin
« Reply #7 on: April 25, 2014, 12:00:52 pm »
i could jiggle the transfer case by hand they were so bad. $25 later all brandy new
Offline ratdawger
Re: The Gray Goblin
« Reply #8 on: April 27, 2014, 01:18:34 am »
Nice purchase, I like the look without the fenders
My friends call me, The thread killer
Offline dvdswan
Re: The Gray Goblin
« Reply #9 on: May 01, 2014, 09:38:22 pm »
coming alone nicely.
Offline FearNoMan78k10
  • A project turned into a complete rebuild
Re: The Gray Goblin
« Reply #10 on: May 02, 2014, 05:43:20 pm »
Definitely a cool build and project !
78 k10 4x4
Offline FlatBlack77
Re: The Gray Goblin
« Reply #11 on: May 02, 2014, 06:31:27 pm »
drove it roughly 200 miles on saturday. sat in a good bit of traffic and it never got over 180 degrees and it never missed a beat it idled perfectly the whole time and i drove it pretty hard to see how it would do.
about 5 miles from home started having a problem with the steering and found out the lower ball joint is shot. so im doing all 4 ball joints both front rotors and pads so itll be all done and right.
Offline FlatBlack77
Re: The Gray Goblin
« Reply #12 on: May 07, 2014, 10:33:10 pm »
9 hours sunday, 4 monday, and 5 hours yesterday and all now all thats left is a brake caliper ordered today installing tomarrow.
did rotors that were so pitted they were grinding the pads down, pads, balljoints that were shot, u joints that were half seized, wheel bearing seals, and the last is a caliper that is so rusted it wont compress to get the pads over the rotor. its been quite a task but its been fun learning to do all this 4x4 stuff
Offline FlatBlack77
Re: The Gray Goblin
« Reply #13 on: July 08, 2014, 10:45:39 pm »
the old tractor reverse light crapped out so i got a set of LED floodloights from northentool.com for $70. they are 1200 lumens each and work very nicely they came with all stainless hardware and are very sturdy
i wanted to mount them where the old light was but there was no room to get in there with a drill to make new holes so i used some aluminum for a mounting bar
 and bright
truck probably hadnt been washed in 5+ years. this is just washing the hood the sides were all built up with crud even worse
finally got the pushbar off my moms old truck and got it cleaned up with fine grade steel wool. it aint perfect but its much better than i was expecting
havent mounted it yet but will soon. im gunna get a nice set of lights to put on it too
Offline FlatBlack77
Re: The Gray Goblin
« Reply #14 on: July 08, 2014, 10:54:51 pm »
heres some recent pics of the Goblin my daily driver and my 77 thats been an on and off project since 2006. recently dug it out and started seriously workin on it again
my pair of Cheyennes
