Author Topic: Need 454 TBI/serpentine belt help.  (Read 14177 times)
Offline Engineer
« on: June 02, 2014, 06:27:28 pm »
This is a pretty simple request.
Does anyone have a 1988~1992 Chevy C/K with a 454 with a serpentine belt that has the stamped steel brackets that can post a pic for me? The engines with aluminum brackets are different, and won't apply to my application.
I am adding a serpentine belt assembly off of a 1990 454 to my '77 project truck and I need pics of the bracketry to make sure I have all that I am supposed to have for a complete assembly. I bought this in a box so I didn't see it installed to know if it is all there.
The A/C pump on my set up has a cast bracket that bolts to the head. However, it seems there should be an additional bracket that braces the compressor to the intake or similar.
So, can anybody help a brother out?
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline ehjorten
Re: Need 454 TBI/serpentine belt help.
« Reply #1 on: June 03, 2014, 08:45:16 am »
Are you talking about a true serpentine system or just multi-rib vee-belt setup?  I have a 1991 TBI454, but it doesn't have a serpentine system, just multi-rib vee-belt.
-Erik-
Offline Engineer
« Reply #2 on: June 03, 2014, 10:56:41 am »
I need pics of the full serpentine system.
My belt, pulleys, brackets, accessories, etc. are off of a C/K truck.
Offline outlaw70nova
« Reply #3 on: June 04, 2014, 03:05:08 pm »
Does this help?
Offline Dan75k20
« Reply #4 on: June 04, 2014, 04:24:33 pm »
That looks awesome
Offline Engineer
« Reply #5 on: June 04, 2014, 10:19:53 pm »
Thanks outlaw, but actually the way my brackets are arranged the tensioner is on the same bracket as the alternator.
It looks, in your photo, that the A/C compressor mounts farther away from the center of the engine than mine does.
However, do you have a photo of the back of the A/C compressor? That is where I suspect there is a brace that is missing from my set up.
« Reply #6 on: June 07, 2014, 06:35:08 pm »
Quote
I guess all requests are pretty simple aren't they? Finding the answers aren't always so simple
Offline Engineer
« Reply #7 on: June 07, 2014, 08:18:22 pm »
Thanks for posting that Vile.
I found the A/C compressor bracket I was looking for. Part number 14103104. This works for the 1988~1990 model year. In 1991 GM used an improved bracing method that used two bars. Unfortunately the two bars need a threaded boss on the intake. My Holley Strip Dominator doesn't have this boss. I will probably use the 14103104 brace in conjunction with a brace that I liberated from a '93 small block.
Thanks to all who replied.
Also in my expansive search I found a guy who replaced the smog pump with a second alternator. Hmmmm.....
« Reply #8 on: June 07, 2014, 09:03:48 pm »
Quote
     That right there should be in some kind of holy grail or something, Maybe etched in stone somewhere.   :D
