th-350 gone bad
Topic: th-350 gone bad (Read 11892 times)
Dan75k20
th-350 gone bad
June 19, 2014, 11:03:56 am »
So it looks like a drum has gone bad in my transmission it is shifting erratically and down shifting way too soon until I lift off of the gas also sounds like something is rattling around inside of the transmission unless i t is in neutral modulator is connected and the kickdown is also connected . I talked to monster transmission. the good: transmission is under warranty and will be rebuilt with a stronger drum that they install In the monster ss and also send a new torque converter. The bad: I have to pay $250.00 for shipping supply new synthetic fluid $130.00 and my labor bought the HD transmission rated up to 400 hp so this wouldn't happen! 3 days to ship 3 days to rebuild 3 days to ship back to me. Their builder basically told me the forward drum is not much better than stock that they install in the trans also the weight of the truck and torque that my engine makes probably caused this not to forget I have 33 12.50 16.5 tires on the truck . in hind sight I would have spent the extra money for stronger parts in the stronger transmission this just sucks that my truck will be out of commission for over a week I'll post pictures of everything as soon as I start working on the truck
Last Edit: June 19, 2014, 11:08:56 am by Dan75k20
BADAZ chevy guy
Chevy! My drug of choice!
Re: th-350 gone bad
June 19, 2014, 12:35:59 pm »
TH350's are getting hard to find. At leased running ones that is. Blew mine a month ago and finely opted for a used 1993 700R4 (4L60). Haven't installed it yet. (Still getting all the parts I need for a full swap.) So I don't know if it needs a rebuild. Hope not.
CAUTION! Do NOT open vent wing if speed is above 130 MPH!
My build threads:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=28250.msg235337#msg235337
http://67-72chevytrucks.com/vboard/showthread.php?t=624182
bd
Re: th-350 gone bad
June 19, 2014, 01:19:21 pm »
Quote from: Dan75k20 on June 19, 2014, 11:03:56 am
So it looks like a drum has gone bad in my transmission....
Bummer! Sorry to hear that. Sounds like they see drum failures often. At least the builder is standing behind their product with a n/c upgrade. Still not pleasant, though. Labor, consumables and shipping to R&R under aftermarket warranty are nearly always at the consumer's expense.
Dan75k20
Re: th-350 gone bad
June 24, 2014, 03:28:52 pm »
so I dropped the trans pan to see what was going on and email monster transmission pictures something is definitely broken in there
Sent from my Nexus 5 using Tapatalk
sbx22
1974 1/2 ton 350 sbc
Re: th-350 gone bad
June 27, 2014, 08:41:45 pm »
Wow, something is definitely wrong. Hope things work out for you.
Re: th-350 gone bad
June 27, 2014, 10:55:14 pm »
in my recent transmissions searches i think i have read that monster has a bad rap for crappy trans. still think its messed up you have to pay shipping and for fluid
Re: th-350 gone bad
June 27, 2014, 10:57:12 pm »
http://monster-transmission.pissedconsumer.com/
so much they even have a website just for them
skinu
Re: th-350 gone bad
June 28, 2014, 01:59:06 pm »
THATS TOUGH LUCK, BUT FOR THAT PRICE AND A LITTLE TIME AND PATIENCE YOU CAN JUST ABOUT BUILD A STRONGER DUAL FED WITH A STRONGER DRUM AND A BETTER CASE ,THERES A BOOK I THINK ITS BY RON SESSION ILL GET MY LOANED ONE BACK BUT I GOT MINE AT A BOOK STORES BUCK A BOOK BOX AND ITS WORTH IT ALSO JUST LOOK ON THE SITE GUYS HERE WILL TELL YOU WHAT TO LOOK FOR AND I WOULD HAVE LOOKED AT A T350 WITH A 700R4 1ST GEAR ITS WHAT WE BUILT MY SON WAS SHOWN THIS AND ITS 1ST IS DEEP ITS A WEIRD 1-2 SHIFT BUT ITLL PULL YOU IN THE SEAT
Last Edit: June 28, 2014, 08:24:34 pm by bd
Re: th-350 gone bad
June 28, 2014, 11:46:17 pm »
Dan75k20
Re: th-350 gone bad
July 08, 2014, 08:29:02 pm »
New update bought a working th 350 and a np203 for 40 I know It works it was in a friends truck and he swapped to a nv4500 and 205 bucks today 203 shifts like butter I am going to swap the th 350 and send mine back to monster they are supposed to install a hardened drum and better parts this time
Dan75k20
Re: th-350 gone bad
July 08, 2014, 08:29:37 pm »
Dan75k20
Re: th-350 gone bad
September 16, 2014, 11:40:35 am »
So finally its time i r&r my transmission truck finally stopped moving
Dan75k20
Re: th-350 gone bad
September 16, 2014, 11:47:24 am »
Lol at least i have reverse to back it into the shop
Re: th-350 gone bad
September 16, 2014, 07:32:34 pm »
Sounds like they are making excuses. Your tire size and weight of the truck should hardly be an issue for a thoroughly rebuilt TH350. Why don't they just send you an exchange unit?
Dan75k20
Re: th-350 gone bad
September 21, 2014, 09:27:39 am »
So heres the monster in a bucket and my craigslist 40 dollar trans ready to go in
th-350 gone bad
