Author Topic: AFTERMARKET TACH  (Read 29889 times)
Offline 1986GMCSierra
AFTERMARKET TACH
« on: December 27, 2014, 12:23:28 am »
this is kind of an electrical/engine question so i am just going to post it here.. where does the wire for the tach go into the distributor on a 305... does anyone have a picture of where you put yours.. and the motor didnt come with a tach from the factory
Re: AFTERMARKET TACH
« Reply #1 on: December 27, 2014, 12:50:28 am »
the plug on the distributor thats says "tach". its right beside the big red wire near the top of the cap. its a male spade connector so you need to have a female end on your wire
« Reply #2 on: December 27, 2014, 01:23:38 am »
Offline FlatBlack77
« Reply #3 on: December 27, 2014, 06:15:40 am »
you will have to put a female connector on the wire. one of these
it can be a pain in the bum to get it hooked up properly because it plugs in from the bottom and you can see it. but you could just take the coil cover off
« Reply #4 on: December 27, 2014, 11:58:22 am »
my distributor isnt as clean but i know where it is thank you for the help
« Reply #5 on: December 27, 2014, 11:59:34 am »
what kind of tachometers are you using(pictures would be cool)
« Reply #6 on: December 27, 2014, 05:06:10 pm »
This is my style
« Reply #7 on: December 27, 2014, 05:11:22 pm »
In my crew cab I want the stock look but I know I'm going to need a pyro gauge for the Cummins so I'm going to probably get the pods then I might get the new Dakota gauge
« Last Edit: December 27, 2014, 05:15:49 pm by Irish_Alley »
Offline LTZ C20
« Reply #8 on: December 27, 2014, 07:00:10 pm »
I want the Dakota digital too, the blue alloy or whatever it is. It's the blue and grey one without the carbon fiber.
LTZ Cheyenne C20
« Reply #9 on: December 27, 2014, 07:38:17 pm »
i would love to put dakota digital gauges in mine but their just to frekin expensive... but they sure do look nice
Offline FlatBlack77
« Reply #10 on: December 27, 2014, 10:03:19 pm »
i have a sunpro supertach 2 in my k10(pic) and a small 8k autogage with shift light in my c10. both are mounted in the same spot
Offline LTZ C20
« Reply #11 on: December 27, 2014, 10:40:36 pm »
86GMC,  empty your inbox! Lol
LTZ Cheyenne C20
« Reply #12 on: December 27, 2014, 11:01:51 pm »
ok i did.. it doesnt hold very many messages
« Reply #13 on: December 27, 2014, 11:03:04 pm »
did you have to drill holes to mount the tach there? how did you mount it?
Offline FlatBlack77
« Reply #14 on: December 28, 2014, 10:07:14 am »
there is a screw there that hold the trim piece down. i took the screw out and made a small bracket with a hole in it and used that screw to hold it down.
ive also seen them mounted on top of the steering column but thats just not my thing
