Author Topic: Re-installing AC  (Read 43326 times)
Offline hatzie
Re: Re-installing AC
« Reply #30 on: March 30, 2016, 09:19:41 pm »
They really should have designed V-A to work with the factory controls though.
Replacing the HVAC box with a more compact electronic unit why not replace the cable controls?
I thought they looked similar to the factory controls. Are they really cheesy?
Sent from my SM-P605V using Tapatalk
Online VileZambonie
« Reply #31 on: March 31, 2016, 09:21:28 pm »
I think the controls look horrible if you want that factory look in the dash. This was was why I did not purchase a VA unit altogether and ended up going a different route.
Offline hatzie
« Reply #32 on: April 01, 2016, 04:05:58 pm »
I've never seen them up close and personal.
Online VileZambonie
« Reply #33 on: April 01, 2016, 05:10:29 pm »
Looks like they've mildly improved the controls since I last inquired but they still could have done something to accommodate those that want to retain the factory control look.
http://www.vintageair.com/2012catalog/2012%20VintageAir%20Catalog%20Final%20WEB%20(Page%2036).pdf
Offline CA Big Red
    • Big Red Squarebody
« Reply #34 on: April 03, 2016, 05:36:50 pm »
I agree Vile, they could have given us a GM looking option for the faceplate. However, the mechanical looking version is at least an attempt.
"You don't know what you don't know."
1978 Scottsdale Stepside
383 w/ 4" lift & 35" BFG
Offline CA Big Red
« Reply #35 on: April 03, 2016, 05:37:59 pm »
Hatzie, the cable controls are replaced with the V/A unit
Offline hatzie
« Reply #36 on: April 03, 2016, 06:47:02 pm »
I realized that.  I believe they use servo motors like most newer OEM systems.
They could and should make them look similar to the factory unit.  It could be done with a small effort...  just put Vintage Air in script on the Lexan face.
Offline CA Big Red
"Key On Accessory" for Vintage Air install
« Reply #37 on: December 04, 2016, 10:14:26 am »
I'm down to one last wire in my Vintage Air install. Everything is ready to go, but one wire and getting it charged with refrigerant.
I haven't wired anything to the ignition switch before, so I am not clear on how this purple wire is supposed to tap into the ignition switch like they have in the wiring diagram.
I can see the ignition switch on the back of the column, but that is as far as I've gotten and when I research this to find improved instruction, photos or videos, I don't see anything.
Where do I actually connect the purple wire to?
Online bd
Re: "Key On Accessory" for Vintage Air install
« Reply #38 on: December 04, 2016, 03:15:58 pm »
Don't connect to an ignition source.  Instead connect to accessory.
Look at the factory fuse box.  Along the middle of one edge are two power tap cavities marked "ACC FUSED."  Both power taps are protected by the 15-amp "RADIO - IDLE STOP" fuse.  Connect to either terminal.  This will power the circuit in all "Key ON" positions except crank.  It prevents extraneous load on the battery while cranking the engine.
Offline CA Big Red
« Reply #39 on: December 04, 2016, 03:19:41 pm »
Awesome. Done and done.
Offline CA Big Red
« Reply #40 on: December 04, 2016, 03:20:08 pm »
I wonder why vintage doesn't suggest that?  It's way easier to see and get to.
Offline hatzie
« Reply #41 on: December 04, 2016, 10:52:53 pm »
You could use the heater power wire.  Heat and AC are a sub harness. With an ignition switched power wire.
« Last Edit: December 05, 2016, 02:43:02 pm by hatzie »
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #42 on: December 05, 2016, 04:51:30 pm »
Now I'm putting a new floor mat down on Sunday.
Do you have any pics of this installed? And is it the full vinyl floor? Sorry to side track a little.
 1986 Chevy K30(under repair)
Offline 76Texan
  • 76 Scottsdale Owner
« Reply #43 on: December 05, 2016, 07:02:20 pm »
The liner material you sprayed on behind the dash. Did you put the old heat protective pad material behind the dash as well?
Mine was nasty and dusty so now I am pulling everything from that side. Thought it best to just spray it with a heat protecting type spray.
1976 Scottsdale K10
Offline CA Big Red
« Reply #44 on: December 06, 2016, 11:30:00 pm »
I do!  Here are a couple before and afters:
The new floor pans
The lizard skin
Laying out the vinyl attempt
Installed
I have all of the trim, but I'm going to install a nice stereo, run speaker wire, etc before I finish all that.
