SOLVED: HELP WONT START
Topic: SOLVED: HELP WONT START (Read 23202 times)
78BIG-TEN
Re: HELP WONT START
Reply #15 on:
January 17, 2015, 10:30:20 am »
Yep points system obsolete this day and age.Just leaving the key on with them closed can screw them up
LTZ C20
Re: HELP WONT START
Reply #16 on:
January 17, 2015, 10:50:51 am »
I think the moral of the story here is, GM stopped using points 40 years ago for a reason. It sucks. Modern ignition coils on new cars now and even back when individual cylinders started getting their own coils, is all based of the reliability and efficiency of HEI ignition.
LTZ Cheyenne C20
Dr_Snooz
"I like to take hammers, and just break stuff"
Re: HELP WONT START
Reply #17 on:
January 17, 2015, 09:04:35 pm »
Well, just to be the devil's advocate, a points distributor will still work after an EMP attack or a Carrington event. Can't say that for HEI. LOL
Neospartan
Re: HELP WONT START
Reply #18 on:
January 21, 2015, 11:46:30 am »
Thank you guys for all the help. Is there a HEI conversation kit you would recommend? I'm looking at HEI distributors and they range from 50-300 dollars, so I'm rather confused with what I need or should get.
Re: HELP WONT START
Reply #19 on:
January 21, 2015, 02:06:07 pm »
red $45
http://www.ebay.com/itm/HEI-One-Wire-Distributor-Red-for-Pontiac-301-326-389-400-421-428-455-V8-E-Z-/191425368132?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c91d75044&vxp=mtr
Clear $47
http://www.ebay.com/itm/Chevy-SBC-350-BBC-454-65K-Coil-HEI-Electronic-Distributor-Clear-Cap-/181567616389?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a4645f585&vxp=mtr
Nother clear $49
http://www.ebay.com/itm/SBC-BBC-Chevy-v8-HEI-Distributor-50-000-Volt-SUPER-COIL-w-Clear-Cap-50k-Volt-/201205002428?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ed8c0b0bc&vxp=mtr
Black 46.95
http://www.ebay.com/itm/New-305-327-350-400-454-Chevy-HEI-Distributor-Complete-w-Black-Cap-SBC-BBC-V8-/111547761514?pt=Motors_Car_Truck_Parts_Accessories&hash=item19f8c3c36a&vxp=mtr
timthescarrd
Re: HELP WONT START
Reply #20 on:
January 21, 2015, 02:37:55 pm »
I've had a $45 ebay HEI for two years now with not a single issue. Not sure on the changeover procedure casue mine had HEI already, and especially if you need to keep the smog system.
You should also check on your choke to be sure it is operating properly
Re: HELP WONT START
Reply #21 on:
January 21, 2015, 02:41:24 pm »
one thing about the hei is all you need a hot with the key on both "on" and "start"12v to the distributor and she will work lol
Jason S
Re: HELP WONT START
Reply #22 on:
January 21, 2015, 04:39:07 pm »
An HEI swap will also require different plug wires.
The original power wire to the + side of the coil "can" work for an HEI, but it is a resistor wire and should be replaced or bypassed with a non-resistance power supply wire.
Re: HELP WONT START
Reply #23 on:
January 21, 2015, 07:53:48 pm »
the 12v on a points system should be coming off the starter solenoid to the coil
Re: HELP WONT START
Reply #24 on:
January 21, 2015, 08:26:32 pm »
Quote from: Irish_Alley on January 21, 2015, 07:53:48 pm
This only supplies whatever available voltage the system has during cranking. Once the key is released from the cranking position the resistance voltage is applied. A fused key on & crank B+ source to the coil is required for an HEI retrofit
Re: HELP WONT START
Reply #25 on:
January 21, 2015, 08:29:04 pm »
tanks vile
Neospartan
Re: HELP WONT START
Reply #26 on:
February 09, 2015, 12:51:34 am »
Okay so I purchased the second clear HEI I got it in the mail yesterday, now what wires should I get?
Neospartan
Re: HELP WONT START
Reply #27 on:
February 14, 2015, 05:30:08 pm »
HEI distributor is in, I connected the red wire from the distributor bat side to my existing yellow wire that was connected to the positive side of the original coil. I checked the wire for volts and it read 11-12. I spliced my red wire to the yellow and when I tried to start I heard a pop and everything went dead and nothing works. Checked the fuses under the dash they are all good. Dont know what's wrong now.
Re: HELP WONT START
Reply #28 on:
February 14, 2015, 06:48:53 pm »
You cannot use the resistance wire on the HEI
You need to run a fused 12V 12 gauge wire from a Key On source at the fuse panel to the distributor. Clip the resistance wire back and tape it up good same with the wire that goes to the R terminal on the starter. Check to see if you blew a fusible link.
Neospartan
Re: HELP WONT START
Reply #29 on:
February 14, 2015, 10:49:56 pm »
Okay now what about my tachometer wire? I don't have a tachometer.
