Author Topic: stalls when i give it gas in gear  (Read 5709 times)
Offline Sock
« on: February 01, 2015, 06:27:55 pm »
Hey all, i have a 1986 chev halfton...305. I live in canada but anytime its like 5 degrees Celsius or below my truck takes a long time to heat up and if i try to drive it before it heats up it stalls...i can give it gas while its in neutral or park and it wont stall..but as soon as i put it into reverse or drive and give it a little gas it sputters and just dies. i was thinking heatriser but aren't those normally open? if it were why would it be stalling? any help would be greatly appreciated. thanks! its got electric choke.
Offline 78BIG-TEN
Re: stalls when i give it gas in gear
« Reply #1 on: February 02, 2015, 08:52:35 am »
Check choke adjustment,choke pull-off adjustment
Offline Sock
« Reply #2 on: February 02, 2015, 04:51:34 pm »
im really bad with carbs. can you briefly go into detail or you think googling would be better?
« Reply #3 on: February 04, 2015, 04:59:50 pm »
Is the choke working?
« Reply #4 on: February 04, 2015, 07:25:31 pm »
What distributor are you running?
Offline Sock
« Reply #5 on: February 05, 2015, 05:31:16 pm »
rochester quadrajet, choke works it kicks down after awhile.
Offline Stewart G Griffin
« Reply #6 on: February 05, 2015, 07:59:01 pm »
Do you have a tach?
Offline Sock
« Reply #7 on: February 15, 2015, 07:39:07 pm »
yes i added a tach not too long ago, when its in idle (park/neutral) its fine but soon as i put it into gear it barely gets 600rpm, tried adjusting the carb (the little spring piece on the right when looking into the engine compartment) and it seems to only adjust the idle rpm.
« Reply #8 on: February 19, 2015, 08:40:08 pm »
What kind of choke is on it?  manual or?  Are you letting it warm up enough before kicking it off?
Offline Sock
« Reply #9 on: February 22, 2015, 09:44:33 pm »
electric choke, yes im letting it warm up plenty...is there any way of adjusting/tweaking with my elec choke?
