Author Topic: 79 c20 turn singals  (Read 8303 times)
Offline MEXICANKAMIKAZE
  • Chevy Padawan
79 c20 turn singals
« on: March 18, 2015, 12:56:43 am »
so i have a 79 c20 and im having problems with the turn signals. whenever i pull the lever for left or right the front indicators work fine but the back lights trigger the hazards whenever i turn for left or right? any ideas? could it be blown out fuses or the actual lever itself
Re: 79 c20 turn singals
« Reply #1 on: March 18, 2015, 02:19:10 am »
so when you turn on the left or right both sides light up on the rear almost like you have hazards on?
  • Chevy Padawan
« Reply #2 on: March 18, 2015, 02:33:37 am »
yes exactly what happens
« Reply #3 on: March 18, 2015, 02:50:35 am »
i would think a ground but normally a bad ground will cause more problems than just one bulb screwing up. when you put the turn signals on do you have brake lights? how bout running lights?
  • Chevy Padawan
« Reply #4 on: March 18, 2015, 01:47:52 pm »
yes my brakes still work when i have them on
« Reply #5 on: March 18, 2015, 02:02:42 pm »
You going to have to trace the wires something is getting crossed up.  What happens when you turn on the hazzards?
  • Chevy Padawan
« Reply #6 on: March 19, 2015, 01:26:33 pm »
i just got the truck and the interior is awful and i cant figure out where the hazards button is
« Reply #7 on: March 19, 2015, 06:35:26 pm »
It should be on the passenger side of the steering column, behind and below the key.
  • Chevy Padawan
« Reply #8 on: March 20, 2015, 02:02:46 pm »
yea i dont have a hazard botton
« Reply #9 on: March 20, 2015, 11:32:29 pm »
is there a hole in the column about 4 o'clock?
« Reply #10 on: March 20, 2015, 11:33:26 pm »
maybe here
  • Chevy Padawan
« Reply #11 on: April 08, 2015, 01:25:34 am »
forgot my password but are you pointing at where your screwdriver is?
« Reply #12 on: April 08, 2015, 01:34:11 am »
nope the little knob on the side of the steering column that says "hazard" about in the 4 o'clock position
  • Chevy Padawan
« Reply #13 on: April 08, 2015, 01:50:37 am »
oh ok there is no hazard knob at all but there is a hole and i stuck a screw in there so i can function it and when i push it in i my turn signals completely stop working
Offline roundhouse
79 c20 turn singals
« Reply #14 on: April 08, 2015, 01:03:48 pm »
A lot of this is run thru. The turn signal controller
The white doughnut looking deal the lever screws in
I'd replace that first
Its about $25 at any auto parts store
Next I'd replace the bulbs and double check the wiring
See if you're getting power to the light socket
