73-87 Chevy & GMC Trucks
79 c20 turn singals
Topic: 79 c20 turn singals (Read 8306 times)
MEXICANKAMIKAZE
Chevy Padawan
79 c20 turn singals
March 18, 2015, 12:56:43 am »
so i have a 79 c20 and im having problems with the turn signals. whenever i pull the lever for left or right the front indicators work fine but the back lights trigger the hazards whenever i turn for left or right? any ideas? could it be blown out fuses or the actual lever itself
Re: 79 c20 turn singals
March 18, 2015, 02:19:10 am »
so when you turn on the left or right both sides light up on the rear almost like you have hazards on?
MEXICANKAMIKAZE
Chevy Padawan
March 18, 2015, 02:33:37 am »
yes exactly what happens
March 18, 2015, 02:50:35 am »
i would think a ground but normally a bad ground will cause more problems than just one bulb screwing up. when you put the turn signals on do you have brake lights? how bout running lights?
MEXICANKAMIKAZE
Chevy Padawan
March 18, 2015, 01:47:52 pm »
yes my brakes still work when i have them on
March 18, 2015, 02:02:42 pm »
You going to have to trace the wires something is getting crossed up. What happens when you turn on the hazzards?
MEXICANKAMIKAZE
Chevy Padawan
March 19, 2015, 01:26:33 pm »
i just got the truck and the interior is awful and i cant figure out where the hazards button is
March 19, 2015, 06:35:26 pm »
It should be on the passenger side of the steering column, behind and below the key.
MEXICANKAMIKAZE
Chevy Padawan
March 20, 2015, 02:02:46 pm »
yea i dont have a hazard botton
March 20, 2015, 11:32:29 pm »
is there a hole in the column about 4 o'clock?
March 20, 2015, 11:33:26 pm »
maybe here
MEXICANKAMIKAZE
Chevy Padawan
April 08, 2015, 01:25:34 am »
forgot my password but are you pointing at where your screwdriver is?
April 08, 2015, 01:34:11 am »
nope the little knob on the side of the steering column that says "hazard" about in the 4 o'clock position
MEXICANKAMIKAZE
Chevy Padawan
April 08, 2015, 01:50:37 am »
oh ok there is no hazard knob at all but there is a hole and i stuck a screw in there so i can function it and when i push it in i my turn signals completely stop working
roundhouse
79 c20 turn singals
April 08, 2015, 01:03:48 pm »
A lot of this is run thru. The turn signal controller
The white doughnut looking deal the lever screws in
I'd replace that first
Its about $25 at any auto parts store
Next I'd replace the bulbs and double check the wiring
See if you're getting power to the light socket
79 c20 turn singals
