Author Topic: 700r4 torque converter lockup  (Read 3569 times)
Offline Abaird24
« on: May 25, 2015, 10:25:00 am »
I picked up a very nice older restored 86 k10 a few months ago.  I did replace the tired 305 with a nicely built 350 that I had.  The truck runs great and shifts fine as well but the 2-3 shift is the where I have concern.  I noticed while swapping engines that the trans is a rebuild that can't have more than a few thousand miles on it.  When it shifts to 3rd gear the torque converter seems to lock up right away and there is a pretty substantial rpm drop that I think is too much.  If I am really putting my foot in it the lock up is a little delayed which is better but I don't know if this is normal or not.  I won't be doing any towing with it and it won't get more than a few thousand miles a year on it anyway but I didn't know if I should be worried or not.  I can provide more info if needed.  Thanks
Re: 700r4 torque converter lockup
« Reply #1 on: May 25, 2015, 11:51:01 am »
Tighten the TV cable 1 click at a time until you get it where you like it
Offline jg1977c20
« Reply #2 on: May 25, 2015, 03:00:32 pm »
you can only properly adjust the tv cable with a pressure guage hooked up to the transmission or you will kill it in no time - the cable controls line pressure . anything else is a lucky guess .
1977 c20 cheyenne camper special 8200gvw
« Reply #3 on: May 26, 2015, 07:48:41 pm »
Not true and increasing the tension on the cable will increase TV pressure which will not harm the trans in any way. Going the other way is what can cause low apply pressure and premature clutch failure.
Offline LTZ C20
« Reply #4 on: May 27, 2015, 03:31:15 pm »
Not true, there is a process to adjusting the cable, it is simple, easy, quick and requires no tools or pressure guages. I've done mine multiple times. Not even GM requires a gauge of any sort for cable adjustment.
LTZ Cheyenne C20
