Author Topic: MSD Digital 6 AL Box... (New)  (Read 5275 times)
Offline 454 Camper Special
« on: June 27, 2015, 01:06:48 pm »
MSD Digital Multispark 6 AL Box.. New out of box.. Paired with a MSD Pro Billet HEI Distributor.. Upon ignition on.. 5 led light flashes..tried starting..now absolutely nothin..!! Trouble checked wiring..to factory specs..all good there.. I'm grounded to body..tight..to bare metal.. Any ideas folks.!? Shout back with any insight..! Appreciated
Sent from my SCH-S968C using Tapatalk
Re: MSD Digital 6 AL Box... (New)
« Reply #1 on: June 27, 2015, 02:07:53 pm »
In your previous thread, 383 Chevy Stroker, you indicated you had a bad ignition module in the MSD distributor.  Did you replace the module?
Offline pneuner750
« Reply #2 on: July 08, 2015, 02:55:39 pm »
I had sort of the same problem. I was told  to tie the ground directly to the battery. I did, it worked. Hope this helps
Sent from my SM-P900 using Tapatalk
« Reply #3 on: July 08, 2015, 07:49:42 pm »
Why don't you post some pics of your setup and the wiring diagram?
Offline pneuner750
« Reply #4 on: July 09, 2015, 03:09:53 pm »
I'll try to tomorrow
Offline pneuner750
« Reply #5 on: July 17, 2015, 05:21:59 pm »
Is it possible the wires under the distributer cap are not insulated from each other. Make sure they can't ground out.
