Members Rides
New truck in the drive
9
10
11
Topic: New truck in the drive (Read 358036 times)
Shifty
I bleed Bowtie red...
Re: New truck in the drive
Reply #135 on:
January 27, 2025, 03:14:35 pm »
Looks good!
98 C2500 ext cab longbed
Dr_Snooz
"I like to take hammers, and just break stuff"
Reply #136 on:
February 04, 2025, 11:11:41 pm »
I printed up these filler blocks to locate the radiator where I need it.
Painted up.
Dr_Snooz
Reply #137 on:
February 08, 2025, 11:45:35 pm »
Dr_Snooz
Reply #138 on:
February 08, 2025, 11:46:47 pm »
I need to buy a CNC machine. Then I can make these out of aluminum.
Dr_Snooz
Reply #139 on:
February 11, 2025, 11:17:53 pm »
Here's the final rad setup.
It's
solid
I have this circuit breaker for the trailer brake.
I don't like having live posts sitting out there for anything to short on, so I designed a cover to protect it.
And some new parking lights.
Last Edit: February 12, 2025, 12:26:41 am by Dr_Snooz
Shifty
Reply #140 on:
February 12, 2025, 11:20:14 am »
Nice fiddly-work!
Dr_Snooz
Reply #141 on:
February 12, 2025, 10:32:35 pm »
I've never really made a loom before, and I'd like this to look nice when I'm done, so this is taking forever.
Dr_Snooz
Reply #142 on:
February 12, 2025, 10:53:30 pm »
The headlight harness I built with my crummy eBay crimpers came apart when I removed the core support. After much had scratching, I think I know how to put it back together again. I have a set of new crimpers coming.
bd
Reply #143 on:
February 13, 2025, 06:18:51 am »
Strip away a suitable length of wire insulation such that the bare wires penetrate to the center of a butt splice (see 'C' in upper image) or completely through a parallel splice (see lower image).
Thoroughly burnish exposed copper wire strands until shiny to remove all surficial oxidation, allowing for even solder flow and adhesion.
Firmly crimp using uninsulated, tinned, brazed-barrel copper butt or parallel splices to create a permanent and mechanically stable connection.
Solder using electrical grade 60/40 or 70/30 rosin core solder to seal against subsequent oxidation and ensure a permanent and stable electrical connection.
Shrink seal using marine grade, adhesive lined, dual-wall polyolefin heat shrink to insulate and reject moisture and corrosive dust intrusion.
Dr_Snooz
Reply #144 on:
February 13, 2025, 08:54:17 am »
Thanks bd. My crimpers were designed for smaller gauge wire than I used on my headlight harness. My crimps just weren't up to the job, especially around the relay connectors where I had a few parallel splices. I never had a problem on the road, but when I disassembled everything, the crimps failed.
I could use some guidance on wire sizing. I want to get a 150A alternator to support the high draw fans. I bought a 1/0 wire from eBay for that purpose, and this monster showed up.
It's the right size per NEC, but it's impractically large. I've noticed that a lot of the factory wiring is undersized also. Nothing's burned up yet, so what am I missing here?
ehjorten
Reply #145 on:
February 13, 2025, 09:30:53 am »
I am sure BD will have better information, but for 150 A alternator, you will never be outputting 150 A continuously, it will only be for maybe a brief period of time, but even assuming you are outputting 150 A, you would be able to support that with a 6 AWG wire at nearly 5 feet of length with a 2% voltage drop. It really depends on the length of the wire.
When I rewired my '69 Chevelle long ago for a CS130 alternator, I ran two 8 AWG wires, which is equivalent to a 5 AWG. It is probably overkill, but it was easier to crimp terminals and route two smaller wires than to deal with one very large gauge wire.
-Erik-
bd
Reply #146 on:
February 13, 2025, 09:57:55 am »
A 150-amp alternator charge lead should be ~5' long. An alternator will push maximum output for 30-40 seconds, at most, before tapering down to <60%. For a 150 amp alternator, 60% is 90 amps. So, hypothetically, the alternator will produce fewer than 90 amps routinely. For your circumstances, a 4-gauge SGX cable is adequate for 80 amps continuous output with a ~1% voltage loss (0.14-volt) across the 5' run (3% loss is the OEM standard). In contrast, a 2-gauge cable is gross overkill, yielding ~0.15-volt loss @ 150 amps continuous. If your alternator generated >70% routinely its life would be dramatically shortened!
For comparison, a 10' long 1/0 cable will carry 300 amps continuously with voltage loss limited to ~3% or ~0.4-volt loss across the cable in a 12.6-volt circuit, which is the minimum specification for a Class 8 truck diesel starter and super heavy-duty for a LD diesel starter.
Last Edit: February 13, 2025, 10:46:41 am by bd
Dr_Snooz
Reply #147 on:
February 13, 2025, 03:47:10 pm »
Thanks guys. So basically, if I do a voltage drop calculation with a 3% loss, that will get me where I need to be? I'm coming from residential wiring where the requirements are quite different. I know I'm missing something because GM was using a 10G wire for the 105A alternator, and 16G wire for the headlights. Just trying to figure out how to do things the right way.
bd
Reply #148 on:
February 13, 2025, 04:37:41 pm »
Acceptable voltage losses depend on the type of load and duty cycle. Typical OEM low- to moderate-load, moderate to high duty-cycle primary circuits (e.g., lights, radio, blower fan, battery charging circuit, radiator fans, power windows, etc) are based on 3% loss. Ultra high-load, low duty-cycle starter circuits are based on 5% to as much as 7% losses.
My personal preference during a wiring repair or rewire varies with the type of appliance, duty cycle, repair cost, thermal exposure, space/flexibility constraints, and my experience, generally targeting 1% - 2.5% loss; ~4% for cranking circuits. Opinions will vary with the electrician. I nearly always employ GXL or SXL insulated wire.
Dr_Snooz
Reply #149 on:
February 26, 2025, 10:42:49 pm »
I'm still farting around on this rad install. The wiring is all done and nothing caught fire when I connected the battery, so that's good.
I had to move the heater hose routing around since the new rad doesn't have a heater hose provision.
According to Summit, this Griffin CU-70013 is a "direct-fit" for my truck. It's nothing of the kind, so I don't know why I was surprised to find that the nipples are larger than those on the factory rad, but I was. Now I'm trying to figure out how to make that all work. I ordered some universal hoses. One was the longest available, but still too short. The other couldn't make the dog-leg twists of the factory hose. So now I'm on the order parts -> wait a week to get them -> be disappointed -> order more parts merry-go-round.
Last Edit: February 26, 2025, 10:55:33 pm by Dr_Snooz
9
10
11
Members Rides
