Author Topic: 71-78 brake line thread size?  (Read 15480 times)
Offline Catrik
« on: October 15, 2015, 09:11:52 am »
Guys from Rough Country said their 71-78 front brake line http://www.roughcountry.com/extended-front-brake-lines-89340s.html will fit an 86, even though it doesnt say so.. Well it does fit but the way it attaches to the brake line bracket is different. I thought I just put a nut on the outside thread, but what is the size?
Offline Catrik
Re: 71-78 brake line thread size?
« Reply #1 on: October 17, 2015, 08:51:01 am »
I mean the thread pointed in the picture
« Reply #2 on: October 17, 2015, 11:55:00 am »
Did you ask Rough Country (1-800-222-7023 or email) or post your question under FAQ - ASK A QUESTION on their website?  If you already have the hoses, take them to a local hardware store and use their thread diameter and pitch gauges to determine the size.
Offline enaberif
« Reply #3 on: October 17, 2015, 12:59:09 pm »
The issue is that from 73-78? They used a 7/8 banjo bolt then in 79 then changed to the 10mm standard banjo. There are differences in the hoses.
« Reply #4 on: October 17, 2015, 01:25:51 pm »
It is retained by a stamped nut
« Reply #5 on: October 17, 2015, 01:37:30 pm »
Also referred to as a pal nut.
« Reply #6 on: October 17, 2015, 04:19:09 pm »
Although PAL nuts were used by the factory and are somewhat self-locking, they easily distort when square engagement with the nut using a fixed size wrench is not possible.  If access to tighten the nut inside the frame is limited I recommend an internal star washer and plated steel nut to retain the bulkhead fitting.  For easier disassembly in the future smear a little anti-seize on the external threads of the bulkhead fitting before inserting it through the frame.
Offline enaberif
« Reply #7 on: October 17, 2015, 04:58:25 pm »
When I did mine I had to use a large fender washer to keep the hose from going through the frame hole then I just used the pal washer on the backside.
Offline Catrik
« Reply #8 on: October 18, 2015, 06:05:36 am »
I did ask Rough Country, they didn't know. They just get them in a box and ship them forward.
The local bolt store probably doesnt have so special nuts (I live in a world of metrics), I'm thinking of making one from brass, I just need to know the thread and wouldn't like to take it off just to measure it.
I tried going through Rockauto but didnt see any of those pal nuts, only the hold down clips.
« Reply #9 on: October 18, 2015, 02:14:08 pm »
If I have spare in the garage I'll measure one
Offline enaberif
« Reply #10 on: October 18, 2015, 03:24:08 pm »
Use napas website or rockauto to get the fitting size. It is what I did.
Offline Catrik
« Reply #11 on: October 19, 2015, 10:06:26 am »
I feel silly now.. That's what I always do first but I just didnt look hard enough. Looks like it is 5/8"-18 and it sounds about right http://www.rockauto.com/catalog/moreinfo.php?pk=1362386&cc=1294938&jnid=511&jpid=3
I hope we have that sized tap at work!
