Brakes and Braking Systems
71-78 brake line thread size?
Topic: 71-78 brake line thread size? (Read 15496 times)
Catrik
October 15, 2015, 09:11:52 am »
Guys from Rough Country said their 71-78 front brake line
http://www.roughcountry.com/extended-front-brake-lines-89340s.html
will fit an 86, even though it doesnt say so.. Well it does fit but the way it attaches to the brake line bracket is different. I thought I just put a nut on the outside thread, but what is the size?
Catrik
Re: 71-78 brake line thread size?
October 17, 2015, 08:51:01 am »
I mean the thread pointed in the picture
bd
October 17, 2015, 11:55:00 am »
Did you ask Rough Country (1-800-222-7023 or
email
) or post your question under
FAQ - ASK A QUESTION
on their website? If you already have the hoses, take them to a local hardware store and use their thread diameter and pitch gauges to determine the size.
enaberif
October 17, 2015, 12:59:09 pm »
The issue is that from 73-78? They used a 7/8 banjo bolt then in 79 then changed to the 10mm standard banjo. There are differences in the hoses.
October 17, 2015, 01:25:51 pm »
It is retained by a stamped nut
October 17, 2015, 01:37:30 pm »
Also referred to as a pal nut.
bd
October 17, 2015, 04:19:09 pm »
Although PAL nuts were used by the factory and are somewhat self-locking, they easily distort when square engagement with the nut using a fixed size wrench is not possible. If access to tighten the nut inside the frame is limited I recommend an internal star washer and plated steel nut to retain the bulkhead fitting. For easier disassembly in the future smear a little anti-seize on the external threads of the bulkhead fitting before inserting it through the frame.
enaberif
October 17, 2015, 04:58:25 pm »
When I did mine I had to use a large fender washer to keep the hose from going through the frame hole then I just used the pal washer on the backside.
Catrik
October 18, 2015, 06:05:36 am »
I did ask Rough Country, they didn't know. They just get them in a box and ship them forward.
The local bolt store probably doesnt have so special nuts (I live in a world of metrics), I'm thinking of making one from brass, I just need to know the thread and wouldn't like to take it off just to measure it.
I tried going through Rockauto but didnt see any of those pal nuts, only the hold down clips.
October 18, 2015, 02:14:08 pm »
If I have spare in the garage I'll measure one
enaberif
October 18, 2015, 03:24:08 pm »
Use napas website or rockauto to get the fitting size. It is what I did.
Catrik
October 19, 2015, 10:06:26 am »
Quote from: enaberif on October 18, 2015, 03:24:08 pm
I feel silly now.. That's what I always do first but I just didnt look hard enough. Looks like it is 5/8"-18 and it sounds about right
http://www.rockauto.com/catalog/moreinfo.php?pk=1362386&cc=1294938&jnid=511&jpid=3
I hope we have that sized tap at work!
