Author Topic: Vinyl flooring and Sound Insulation Mat questions  (Read 4455 times)
Offline Chuck Step-a-side
« on: November 30, 2015, 05:40:30 pm »
I am laying down a vinyl floor mat instead of carpet in my 1984 Chevy Stepside and would like to know what have others owners have used to insulate from heat and noise? Did you put insulation between the flooring and vinyl mat? If yes, then what insulation thickness was used? Thanks and happy holidays, Chuck
Re: Vinyl flooring and Sound Insulation Mat questions
« Reply #1 on: November 30, 2015, 06:07:45 pm »
I would suggest a spray on sound deadener
http://store.secondskinaudio.com/spectrum/
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: November 30, 2015, 07:17:54 pm »
Never heard of it but after checking out the site I'm sold.
« Reply #3 on: December 01, 2015, 10:21:37 am »
That is perfect!! Thanks
« Reply #5 on: December 05, 2015, 05:02:05 pm »
That is awesome. Will any spray gun designed for heavy thick paint do the same spraying job?
Offline philo_beddoe
  • 77 C-10
« Reply #6 on: December 10, 2015, 09:04:34 am »
Wow, that IS a clean finish! I went with a carpet and found some real thick dense padding at a carpet place, NOT the standard lightweight foam stuff they use for indoor carpets. And I had a lot of noise coming through, now it's like i'm in a sound booth, of course, new weather-stripping helps too. In fact I also used it as a under hood insulation and works great. Most of the catalogs sell sound deadning stuff.
Vile, does that stuff also work like "chassis coat" rust prevention, i thought I saw a can in one of your pics.
