73-87 Chevy & GMC Trucks
Filling The Tanks & Making a Mess
Topic: Filling The Tanks & Making a Mess (Read 4423 times)
RAD77C10
January 10, 2016, 01:47:06 am »
I go to fill the right or left tanks, & I'm always running gas on the ground! Is there a way to solve this problem?
FlatBlack77
Cheap Fast Reliable - Pick 2
Re: Filling The Tanks & Making a Mess
January 10, 2016, 08:22:13 am »
you mean there is a leak?
or you mean they are overflowing because the pump doesnt kick off when they get full like it does with newer cars?
if its this one then turn the ignition on and watch the gas gauge go up. just dont fill it so fast that the gauge cant keep up
but this is all if you can see the gauge. if you have a topper or a lift or something this might not be possible
gunrac
January 10, 2016, 08:53:27 am »
Try fueling up while everything is at it's coolest. Weather and vehicle. I think they all have a learning curve where they except it best.
My 85', excepts fuel best, with nozzle hanging 3/4 out of opening, catching the last ring on the nozzle spring.....Had 1 truck....... only take fuel w/a hard left angle on nozzle.
Never Apologize..........as it shows signs of weakness
January 10, 2016, 03:33:13 pm »
fill up on full but when you can hear the tone of the fuel change slow it down
RAD77C10
January 10, 2016, 03:52:45 pm »
The right tank works best with nozzle at 3:00, the left tank at 9:00, then on both go slow! My 1973 C20 never had problems like this truck! There are no leaks, the gas just doesn't want to go down, I hate making a puddle at the gas station.
January 10, 2016, 05:55:09 pm »
You probably have the tank vent plugged
RAD77C10
January 10, 2016, 11:43:04 pm »
I'll pull them off tomorrow & see, Thanks
