Author Topic: Removing stock stereo  (Read 47256 times)
Offline OldGray
  • Ne'er-do-well
« on: February 23, 2016, 05:58:53 pm »
Before I dig into it, what steps are required to remove the stock stereo from the dash?
Is it just Dash trim and then A/C ducting under the dash?
1979 Chevrolet Bonanza / 305 / LWB
Re: Removing stock stereo
« Reply #1 on: February 23, 2016, 06:05:53 pm »
knobs, dash bezel, nuts, support in the back ,antenna and cables. Push AC duct out of the way and it drops right out. What year is it?
Offline OldGray
  • Ne'er-do-well
« Reply #2 on: February 23, 2016, 06:42:59 pm »
It's a '79
Offline enaberif
« Reply #3 on: February 23, 2016, 10:39:52 pm »
Watch your bloody hands and fingers... There is a lot of sharp metal and stuff to stab you!
« Reply #4 on: February 24, 2016, 07:42:32 pm »
What are you replacing it with?
Offline OldGray
  • Ne'er-do-well
« Reply #5 on: February 24, 2016, 08:20:47 pm »
I'm not replacing it.
I love the factory Delco (?) AM/FM. I am going to remove it, take it apart, clean the pots and other electronics, shine it up and then add a 1/8" input so I can use my Phone/MP3 player with it.
Once I have the input installed I can even connect a mini Bluetooth receiver.
« Reply #6 on: February 25, 2016, 08:40:15 am »
Nice. post your progress and good luck
Offline gunrac
« Reply #7 on: February 25, 2016, 11:12:49 am »
Sounds impressive! I'd be very interested in doing or having it preformed on my stock radio......take a lot of pics.
Never Apologize..........as it shows signs of weakness
Offline K20Detroit
« Reply #8 on: February 25, 2016, 11:32:46 am »
On my diesel, I had issues getting it around the pedal brackets.
I don't remember my '79 having pedal brackets in the way, but i did that 5-6 years ago.
Other than that, like Zambonie said, it's pretty straight forward.
Also, technically the plug is a 3.5mm plug. It would convert to approx. 1/8", however the industry term is 3.5mm jack.
Offline OldGray
  • Ne'er-do-well
« Reply #9 on: February 29, 2016, 05:45:27 pm »
Hey - I finally found a write up for the same stereo that I have.
http://67-72chevytrucks.com/vboard/showthread.php?t=447435
I have already removed mine and cleaned the (many) moving parts, so everything moves freely and no more crackle in the volume knob.  So I think I will be doing this mod in the next day or so.  Will let you know how it turns out!
Offline gunrac
« Reply #10 on: February 29, 2016, 09:07:06 pm »
bit elder then mine......same principle, i think.......hec ya.....keep it coming
Offline OldGray
  • Ne'er-do-well
« Reply #11 on: February 29, 2016, 09:20:45 pm »
Couldn't wait!  Ran out to the shop after dinner and installed the Aux Input to my old Delco.  Didn't take too long with the instructions from the thread I linked in my last post.  Tested it and it WORKS GREAT!
Tomorrow I will reinstall in the dash and I will mount the input on the wall of the inside of the open area when you open the ashtray.  I will remove the ashtray and build some sort of mount that will hold the telephone or iPod, and use the cigarette lighter as a charging source.
My plan is to load my MP3 player full of songs from 1979, so when I roll in my '79, I am IN 1979!
Gotta love the internet for stuff like this!
Offline gunrac
« Reply #12 on: February 29, 2016, 09:32:05 pm »
Well.....I usta like ya.........sounds like my doc......keep givin reasons not to smoke......lol.....stay at it.......sounds great
Offline philo_beddoe
  • 77 C-10
« Reply #13 on: February 29, 2016, 09:41:34 pm »
Ok, how do i connect a bluetooth to mine, i have a plain ac delco am/fm and all i get is fm stations and i need to hear michael savage on my way home from work, he's am stations only.
I was going to by a bluetooth speaker from bestbuy and hang from mirror, but would rather go through my 1977 radio. I installed a killer aftermarket factory replica center dash speaker and it sounds great. No am stations come in, probably because im nowhere near any city.
Offline OldGray
  • Ne'er-do-well
« Reply #14 on: February 29, 2016, 10:01:24 pm »
Well this link is where I got the instructions for adding the Aux Input. - http://67-72chevytrucks.com/vboard/showthread.php?t=447435
Once you do that you should be able to use one of these little Bluetooth receivers through that input.
