Author Topic: Bolt in electric fans?  (Read 10330 times)
Offline Stewart G Griffin
« on: March 06, 2016, 05:57:06 pm »
Just wondering if there are any bolt in electric fan units available?
i've seen the ones from Be Cool and that's a little too expensive for me.
Any others?
The cavalier fan from the salvage yard doesn't work, so i'm looking for something new.
Offline SkinnyG
  • Reducing resale value since 8-track days
Re: Bolt in electric fans?
« Reply #1 on: March 06, 2016, 09:10:47 pm »
I'm using dual fans from a Ford Windstar.  With minimal work, it fits darn near perfect.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline gunrac
« Reply #2 on: March 06, 2016, 09:32:02 pm »
I'm assuming a chevy truck......Curios........why ya all see the need to to put an addy fan in?
Never Apologize..........as it shows signs of weakness
Offline SkinnyG
« Reply #3 on: March 07, 2016, 10:03:06 am »
I wanted the engine to get up to temperature more quickly, and more adequately deal with stop-and-go traffic where there isn't much air flow.
Could the stock setup have been fine?  Probably.  It had been for the previous 37 years.  But this was what I wanted, and my engine is no longer stock.
Offline SomeTexan
  • No such thing as too much hp
« Reply #4 on: March 07, 2016, 10:39:50 am »
Fans driven off the front of the engine rob power, fuel mileage and put extra stress on your accessories. Ditching a stock fan for an electric one is always worth it. If done correctly, that is.
86 swb c10, LQ4/glide with 80mm turbo
« Reply #5 on: March 07, 2016, 10:28:02 pm »
1) First thanks, but no ford parts on this truck.  i would sooner put Toyota or even Mopar parts on.  Or even go back to mechanical and shroud.   It's just a "thing" i have......
2) In my case, the 4.3 takes a special, much longer than a v-8, shroud (almost like a tunnel).  i forgot to claim it from the guy i bought the engine off of.  So i can't really run a mechanical fan right now AND i kind of want to run an electric anyways----you should see how much room i have underhood.  Will provide pictures ASAP.
3) BTW, the perma-cool drop in unit is slick and does bolt right in, but it's $680.   And that's just a little too much for me considering i only need it when sitting in traffic.
http://www.summitracing.com/oh/parts/prm-19513/overview/year/1983/make/chevrolet/model/c10
So, right now i'm looking at 2 universal type units from Derale and Spal.   i think i can make one of them work.
« Last Edit: March 07, 2016, 10:31:45 pm by Stewart G Griffin »
Offline SomeTexan
« Reply #6 on: March 07, 2016, 11:55:04 pm »
Have you tried late model Silverado fans? I don't know how the radiator compares size wise, but around here you can find them for cheap.
If it wasn't for your no ford parts rule I would suggest Taurus fans. They are 2 speed, and cheap. I've run them on rock crawlers before with good luck.
Offline Rich84
« Reply #7 on: March 09, 2016, 09:08:05 am »
I am also running a Taurus fan. Using just the low speed it cools quickly. It looks like it belongs and it was very cheap.
Offline Funkatation
« Reply #8 on: March 09, 2016, 05:29:25 pm »
Wind star fans here.
Offline frotosride
    • WFO CONCEPTS
« Reply #9 on: March 09, 2016, 05:38:42 pm »
I have an aftermarket radiator but the shroud I have comes in different variations. I bought thenhaden fans years ago and just added a Jegs fanshroud and it works great especially for the price. You may have to fab up a small bracket on each end but very simple!
« Reply #10 on: March 09, 2016, 05:44:58 pm »
You can build an electric fan fairly easily. I just made one out of aluminum but haven't cut the hole for the fan yet. once i get back on my 74 I'll post how that turned out. eBay has them relatively cheap now with either single or dual fans made to fit these applications.
Offline midas72
« Reply #11 on: March 10, 2016, 04:03:54 pm »
I like the simplicity of the factory engine driven fan, but on my street/ strip car I use a stock 2009 Chevy HHR fan. Keeps 500 plus horse power small block at 180
