Author Topic: Could someone show me with pictures where/how to clean out the cowl?  (Read 8977 times)
Offline Stewart G Griffin
Could someone show me exactly-----like with pictures where to clean out the cowl?
i'm still getting water in the cab.  i have the cowl cover off.
Re: Could someone show me with pictures where/how to clean out the cowl?
« Reply #2 on: April 02, 2016, 08:58:41 am »
i saw that write up and it was very helpful, but i was wondering if anyone had any specific pictures as to problem spots.
« Reply #3 on: April 02, 2016, 12:12:28 pm »
Cleaning out the cowl versus checking for water leak. Which are you trying to do?
« Reply #4 on: April 02, 2016, 11:24:39 pm »
Both.
« Reply #5 on: April 03, 2016, 10:00:01 am »
The link posted above shows you how to clean out the cowl. Hunting down a water leak is best done with a flashlight and have an assistant use a garden hose.
Offline kcwis
I've repaired the rust in the cowl, now where can I find some pourable seam sealer to replace the seam sealer that was in there, ? I also coated the area with por 15. Thanks
Offline hatzie
« Reply #7 on: June 30, 2016, 10:21:21 am »
3M makes a huge array of seam sealers.  Some can be applied over paint and some require bare metal for proper adhesion.
The "3M 08329 Control Flow Seam Sealer" is what 3M recommends for trunk rain trays and roof gutters.  It flows approximately 1 1/2 inches when applied at a 45 degree angle and cures in around 45 minutes.  Use on bare metal.
The "3M 08308 Heavy-Bodied Seam Sealer" can be used on vertical panels in firewall and cowl areas.  Use on bare metal.
3M 8307 can be applied over painted and sanded surfaces.  It flows out like 8329 and can be painted over but do not use self etching primer.
http://multimedia.3m.com/mws/media/399105O/dfu-3mtm-automixtm-self-leveling-seam-sealer-08307-072506.pdf
« Last Edit: June 30, 2016, 10:27:07 am by hatzie »
Offline kcwis
Thanks for the info about the seam sealer, is there another option to apply it other than buying the mix pac dispenser? $600 ??
Offline winky
« Reply #9 on: July 06, 2016, 10:20:14 pm »
Are you against using the 3m seam sealer that is in the caulk tubes?
Offline hatzie
« Reply #10 on: July 08, 2016, 11:53:13 am »
$600 ??? If that's a local price go elsewhere they're fleecing you. Even with the more expensive 3M seam sealer cartridge gun it's right at $100 for the whole shebang
The generic gun for the 3M double barrel mixing tubes is around $35 The 3M gun is around $62...
The 3M Mix tips are around $12.
You can get everything on Amazon...   The tools and mixing tips are Prime shipping eligible...
https://www.amazon.com/3M-08307-Self-Leveling-Sealer-Cartridge/dp/B000PEW40U/ref=pd_sim_263_3?ie=UTF8&dpID=51eVKj5mXTL&dpSrc=sims&preST=_AC_UL160_SR110%2C160_&psc=1&refRID=QWG5GYE6EDJNJY7K30YS
https://www.amazon.com/M200LVMR-Cartridge-Viscosity-Manual-Applicator/dp/B001SN7RKO/ref=pd_bxgy_263_2?ie=UTF8&psc=1&refRID=MXDXCADSX007ZPQ6SPGG
https://www.amazon.com/3M-08571-Caulking-Gun-Cartridge/dp/B002QWYG1O/ref=pd_bxgy_263_3?ie=UTF8&psc=1&refRID=MF1K5TNT7WW5BZ6VH1CW
https://www.amazon.com/3M-08193-Mixing-Nozzle-pack/dp/B0015PI2UY/ref=pd_bxgy_60_2?ie=UTF8&psc=1&refRID=9ACAG20700KRM90467X7
« Last Edit: July 08, 2016, 11:56:08 am by hatzie »
