Author Topic: 4x4 shifter assembly  (Read 8360 times)
Offline Pike1915
  • Trying to kept my sanity
« on: April 08, 2016, 12:18:36 pm »
If I decied to take apart and clean the 4x4 shifter assembly, is there a certain grease that needs to be put back on it or what should I use ?
Offline Pike1915
Re: 4x4 shifter assembly
« Reply #2 on: April 08, 2016, 10:12:44 pm »
Thanks ..for grease ideas
Does anyone have a diagram of how the np203 transfer case shifter should be put back together?  There has been one posted on here and it is ok but I would like more details to it. I have looked every where and came find anything on how the shifter asm box or whatever it's called goes back together.
« Reply #3 on: April 08, 2016, 10:44:32 pm »
Offline Pike1915
« Reply #4 on: April 08, 2016, 11:06:32 pm »
how to assemble one of these.. I am trying to find a little more details about how to do so. i have assembled it and it doesn't seem right and would like to know what should be laying flat or what goes where..
« Reply #5 on: April 08, 2016, 11:36:59 pm »
Offline Pike1915
« Reply #6 on: April 09, 2016, 08:33:48 am »
Yea I already looked at his post
« Reply #7 on: April 09, 2016, 08:35:39 am »
i searched the interweb for a while last night and thats the best i can do.
Offline Pike1915
« Reply #8 on: April 09, 2016, 08:41:09 am »
Yea I know.  Thanks for the help I  appreciate it.  I will just mess around till I get it
Offline Pike1915
« Reply #9 on: April 09, 2016, 09:31:10 am »
I guess my main question is does the pin go all they down through the hook?
Offline hatzie
« Reply #10 on: April 09, 2016, 11:23:18 am »
The gage pin should be run through the shift paddles before you adjust the linkage.  It doesn't stay there.
Have you downloaded the service manuals for your truck?
Offline Pike1915
« Reply #11 on: April 09, 2016, 11:51:31 am »
I have a paper copy of my service manual and its not much help.  I don't need to adjust linkage.  Just took apart to clean because it was full of mod.  But I wasn't sure if all the plates sat flat or if there was some angling and if that pin only went through the 2 shifter plates or all the way down to the hook
« Reply #12 on: April 09, 2016, 02:04:18 pm »
what paper copy of the manual
Offline Pike1915
« Reply #13 on: April 09, 2016, 04:02:05 pm »
I put it back together but the skinner of the two arms hardly moves.. the little one moves from front to back no issue.. is the longer one supposed to move much or not ?
Offline Pike1915
« Reply #14 on: April 09, 2016, 04:05:02 pm »
second pic
