Author Topic: Window channel miss solved  (Read 3038 times)
Offline philo_beddoe
  • 77 C-10
« on: April 08, 2016, 03:31:22 pm »
Vile didnt even see my truck and mentioned (after i complained both door windows were missing the front felt channel) that my rear track needed to be moved forward. I hate taking door panels off because nothing ever lines back up right. Anyway, i finally tuffed it out and dug into it. Sure enough, he was right. The pic shows window rear track in the right spot, finger to the right is where it was. I must have obviously lined it up wrong when i installed all the new felt last fall. Wow, all this time.
Re: Window channel miss solved
« Reply #1 on: April 08, 2016, 05:10:10 pm »
Good job!
Offline big_al273
« Reply #2 on: April 08, 2016, 05:28:03 pm »
ah one of those ahaha, ya my trucks drivers window had this exact problem when i bought it over the summer, when they replaced the drivers door (with a cheap misaligned aftermarket POS) they put the rear window channel in the same wrong spot as yours, they also forgot to keep the G.V.W.R. sticker  :-\
at least it was an easy fix for ya, did you get your door panels lined up right?
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
  • 77 C-10
« Reply #3 on: April 08, 2016, 06:17:25 pm »
Yes, after a little bit of wrestling, i finally got em back on right. Applied a little white lithium to the working mechanisms as well.
