Author Topic: 1978 C10 Paint question  (Read 5399 times)
Offline middleg
« on: April 16, 2016, 02:39:06 pm »
Hi I have a question that may seem really basic to you guys but your input is very appreciated.
I have a 1978 C10 that I am starting to do some body work on to get rid of the rust. I have a set of fenders that I would like to put on but they are only in primer right now. I was wondering if I can put them on the pickup in primer and if they would be alright left like that to drive if it gets painted at a later date. Like I said any input is appreciated. Thanks
1978 C10 Big 10 W/ 350 & 3 on the tree
Offline Captain Swampy
  • Wisconsin
Re: 1978 C10 Paint question
« Reply #1 on: April 16, 2016, 03:00:52 pm »
I'm not a painter, but I think worst case scenario you would sand them and re-prime.
« Reply #2 on: April 16, 2016, 07:50:10 pm »
Primer will not protect them from corrosion.
Offline Rattler12
  • Old Geezer
« Reply #3 on: April 16, 2016, 09:31:03 pm »
A couple coats of an epoxy primer will give you a longer window to overcoat but won't last forever
83 C-10 shorty 454, 5spd, 3:73 posi
« Reply #4 on: April 17, 2016, 06:48:25 am »
You can, but most primers will absorb moisture to some degree. Some types more than others. Epoxy primer will hold up the best.
Are you planning on painting the inside of the fenders? If yes I would suggest painting them. Later when the truck gets painted they can be sanded, and resprayed then.
Offline gunrac
« Reply #5 on: April 17, 2016, 07:18:12 am »
I've have 1 1/2 yr. on China parts w/there primer. No salt, but they definitely need attention now. Just a little heads up.
Never Apologize..........as it shows signs of weakness
Offline middleg
« Reply #6 on: April 23, 2016, 07:43:21 pm »
Thanks guys for your input. I am planning on painting the inside of the fenders so like one of you said I may as well paint the whole thing flat black life the inside and just sand it when it comes time for professional paint
