Author Topic: Front Bumper  (Read 8146 times)
Offline JasonD45
Front Bumper
« on: June 04, 2016, 12:05:29 pm »
I got to design a front bumper at work, and had it test fitted. Finishing up some welding, than paint, it will be semi perminant, until I get a winch and complete modifications and most likely powder coat. Would love to hear some opinions.
Offline LTZ C20
Re: Front Bumper
« Reply #1 on: June 04, 2016, 04:56:36 pm »
It's huge, that's for sure.
LTZ Cheyenne C20
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Front Bumper
« Reply #2 on: June 04, 2016, 07:17:02 pm »
Thinks it's tall and hangs a little low, I would have made the face only as tall as the "D" brackets, and maybe angle the bottom a little more. Just my 2 cents. Otherwise I do like the overall design
 1986 Chevy K30(under repair)
Offline Engineer
Re: Front Bumper
« Reply #3 on: June 04, 2016, 09:43:22 pm »
I like it as is. If you build another one I'll put it on my monster truck. Definitely has that boss appeal.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Re: Front Bumper
« Reply #4 on: June 05, 2016, 08:00:27 am »
one good thing about building a custom bumper it will apeal to some and not to others. i like the design of it need more pictures to see the true fit. so far it does seam like a good bumper that will protect the truck
Offline fitz
Re: Front Bumper
« Reply #5 on: June 05, 2016, 08:37:57 am »
[/quote]
[/quote]
  This could be a great bumper for the states that measure bumper height as a way to regulate lift kit laws.
  Forum member Mike Phillips recently got pulled over in Florida for a bumper height violation.
  This bumper (with a matching rear bumper) could be an attractive solution to the problem.
Offline JasonD45
Re: Front Bumper
« Reply #6 on: June 05, 2016, 09:01:08 am »
The truck is lifted 8", so I was going for a big bumper. I plan on adding a winch into the bumper, so you would only see the rollers on the bumper. I didn't use the original brackets either, it's now bolted straight to the frame via 1/2" plates. Once I get the finished product I will share more photos. I was pretty close on my measurements.
Offline JasonD45
Re: Front Bumper
« Reply #7 on: June 05, 2016, 09:04:00 am »
Thank you all for the input though! I appreciate it.
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
Re: Front Bumper
« Reply #8 on: June 05, 2016, 09:27:01 am »
How much does it weigh?
Offline JasonD45
Re: Front Bumper
« Reply #9 on: June 05, 2016, 09:58:26 am »
I don't know, it had some weight for sure! But with two people lining it up, it wasn't to bad at all, I'd say around 80 pounds, if I had to take a guess. But it was missing the light brackets and lights, as well as two small panels. So when complete it might be around 100ish? It's all 10 guage steel
Offline Engineer
Re: Front Bumper
« Reply #10 on: June 06, 2016, 10:38:39 pm »
Are you going to make more?
Offline 80Chevy4x4
Re: Front Bumper
« Reply #11 on: June 07, 2016, 03:34:02 am »
Where do we place our order?    :)
