Author Topic: oil pressure sending unit  (Read 4100 times)
Offline gwcrim
  • Far from a Newbie
« on: October 04, 2016, 03:45:05 pm »
My truck is a 1980 2wd that came with a 305 and idiot lights in the dash.  I put a factory gauge dash in it and wired it up and it all works fine except for the oil pressure gauge.  Sometimes it doesn't work at all, sometimes it's pegged.
For a sender, I got a Standard PS154 from Summit.  I believe that's the correct number for a 1980 with gauges.  My hunch is that there are two issues.  First, there is a loose connection.  Second, I have the wrong sender.  Is there more than one sending unit or does my trouble lie elsewhere?
Re: oil pressure sending unit
« Reply #1 on: October 04, 2016, 04:03:48 pm »
Try a PS140 and check your connections
Offline gwcrim
  • Far from a Newbie
« Reply #2 on: October 04, 2016, 04:20:36 pm »
I picked up a PS140 on the way home.  Thanks.
Offline gwcrim
  • Far from a Newbie
« Reply #3 on: October 04, 2016, 04:59:00 pm »
Success!
 I'm suspecting that the loose connection is the  plug on the sender wire.  There were some other connections under the hood that were oxidized pretty badly.
Thank you Mr. Z.
