Author Topic: 1987 v10 ignition  (Read 4454 times)
Offline Sgrow87
1987 v10 ignition
« on: October 18, 2016, 05:30:08 pm »
I have a 1987 v10 pickup with a 305 TBI it runs fine in park and neutral but in gear it runs a couple of seconds then quits, we eventually found out that the computer was pulling the timing too far advanced, when we pulled a certain wire to the distributor the timing went to 0 degrees and the idle came back down and it didn't stall in gear. Any Ideas of how to fix that problem?
Offline Captain Swampy
  • Wisconsin
Re: 1987 v10 ignition
« Reply #1 on: October 20, 2016, 09:03:53 pm »
Could be the IAC (idle air control), it screws in on the rear passenger side of the throttle body. The wire you disconnected is for setting the timing. Your timing is correct at 0 degrees with that wire unplugged IIRC.
« Reply #2 on: October 22, 2016, 07:27:37 am »
IAC like swampy said does seam like a good place to start
heres the testing procedures for the sensors and symptoms of defective sensors
http://forum.73-87chevytrucks.com/smforum/index.php?topic=29996.0
« Reply #3 on: October 22, 2016, 08:18:37 am »
Check the TBI base gasket and other areas for vacuum leaks, unplug the EGR hose and see if that makes a difference as well. Your timing isn't too far advanced, it's masking the underlying problem when bypassing the ESC.
Offline Sgrow87
« Reply #4 on: October 24, 2016, 05:27:18 am »
We replaced the distributor and it solved all of are problems, we had checked for vacuum leaks multiple times and the egr isn't leaking, also we rebuilt the throttle body
