Author Topic: truck not getting gas  (Read 8766 times)
Offline Zac.richardson1
« on: November 10, 2016, 08:03:55 pm »
I have a 85 k15 and it stoped getting gas all of a sudden. Ive replaced the fuel pump and even blew through all of the fuel lines and still nothing. someone suggested i put a new cam in it because the old k10s are bad about wearing cam lopes but i wanted to get more information before i blow more money on a cam when i dont need one like i did with the fuel pump. the problem is not the carburetor because its not getting gas to the fuel filter. is it possible i put the fuel pump on wrong?
Offline roundhouse
Re: truck not getting gas
« Reply #1 on: November 10, 2016, 09:07:04 pm »
It's kind of complicated to install the pump correctly
It could be lots of stuff though
When you spin the engine over you should be able to feel the fuel pump moving air
It could be the filter sock in the tank clogged
Could be the lines  etc
Offline bd
« Reply #2 on: November 10, 2016, 09:35:49 pm »
Did you perform some engine work just prior to the symptoms?  Is there a bolt in the fuel pump pushrod retaining hole on the front of the block?
The plated bolt in the image is threaded into a hole that penetrates the pushrod bore.  If the bolt in that hole is too long, it will bind the pushrod and prevent the fuel pump from pumping.  Otherwise for the symptoms to occur suddenly, I concur with Roundhouse.
Offline Captain Swampy
  • Wisconsin
« Reply #3 on: November 11, 2016, 10:34:47 am »
If the fuel pump is installed correctly (it's hard to keep the push rod up). Try a short hose out of a jar or bowl with gas in it. If it works, it's a collapsed screen or fuel line (there is gas in the tank?). If it doesn't, the pump is bad or incorrectly installed. The fuel pump lobe on the cam doesn't usually go bad. The engine runs if you dump some gas in the carb?
1987  350TBI 700R4  4X4  4.56 gears  33" BFG All Terrain
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32209.0
« Reply #4 on: November 11, 2016, 11:46:02 am »
You probably lost your prime. Artificially feed it some fuel and run it for a few.
« Reply #5 on: November 11, 2016, 05:19:48 pm »
well it was running fine until it started sputtering one day, i drove it for a week with it doing that until it got so bad it pulled the mountain 10mph all the way up. i was trying to fix it one day when it just give up and stopped cranking in all
Offline TurboJim
  • idontknowwhatishouldputhere...
« Reply #6 on: November 12, 2016, 12:17:35 am »
If it gave trouble before you put the new parts on then it seems you need to looks elsewhere, I would check the line between the tank and the pump, friend of mine's chevelle rubbed a hole in a hose at the top of the tank, and it just started sputtering one day then died.
Currently owned:1989 Chevrolet R3500 3+3
TBI 454 THM400 transmission dana 70
1992 Pontiac Firebird convertible 3.1L THM700r4 Previously owned:1992 Chevrolet c/k3500 454 4l80E (it got hit august of 2016 and was totaled)
never cruel, never cowardly
« Reply #7 on: November 12, 2016, 06:24:51 am »
I couldn't see it leaking gas anywhere and they're not clogged cause I blew through them
  • Wisconsin
« Reply #8 on: November 12, 2016, 01:14:59 pm »
Does it run if you dump some gas down the carb?
Offline blazer74
« Reply #9 on: November 12, 2016, 03:08:57 pm »
So is there fuel to the pump from the tank?
From the pump to the carb?
Offline TurboJim
« Reply #10 on: November 12, 2016, 04:50:06 pm »
it is a vacuum based fuel system between the tank and the pump, more than likely it won't leak fuel
« Reply #11 on: November 12, 2016, 10:49:29 pm »
i think it would be vacuum based which would make sense why there is no leak. as for pouring gas into the carb we took it off and put it on another truck that needed it and i didnt think to try that. ill have to check if fuel is making it from the tank to the pump but im assuming that it's not
Offline tipoblanco
  • New Users
« Reply #12 on: November 13, 2016, 12:07:20 pm »
 i dont think you could have put the pump on wrong,and check your vacuum lines for cracks or fell off,also like mentioned the screen on the sending unit could be clogged with rust or deteriorated and sucked trash into it,also run a temp line into a gas jug as if coming from the tank and see if its pumping,if you have dual tanks try to switch over to the other one
« Last Edit: November 13, 2016, 12:28:42 pm by tipoblanco »
"84"K10 pickup
Offline blazer74
« Reply #13 on: November 13, 2016, 12:16:16 pm »
Fuel should gravity feed from the tank once you establish flow.
Get yourself a cheap manual lever vac pump or siphon hose and connect to the fuel supply hose and see if you can draw fuel out of the tank first. ( don't want to tell you to such on the hose and get a mouthful of gas.)
« Reply #14 on: November 14, 2016, 02:09:13 pm »
Ok I'll check the lines. Thanks
